[AG-TECH] Ports used in AG - part 2
Roberts, Ian E
ian.roberts at pnl.gov
Fri Oct 25 11:59:58 CDT 2002
Yes, we use VTC to get it started. The port numbers (the three I mentioned are
all incoming) also show up in the title of the main VIC window (in the form of
140.20.92.116/54232 - or whatever the IP and port is). The third number (one
higher than the port used to show the participant video) is just to get the
names of the remote participant windows (we found this accidentally, actually,
when it was typed in wrong and all the windows had IP addresses instead of
names.
The way we used to do it before we noticed the pattern was to use VTC to connect
to a venue that was active (i.e. that has a remote site in it) and our network
guy was able to see which ports were being denied from the Argonne bridge IP
address.
-----Original Message-----
From: Randy Groves [mailto:randy.groves at boeing.com]
Sent: Friday, October 25, 2002 9:51 AM
To: Roberts, Ian E
Subject: RE: [AG-TECH] Ports used in AG - part 2
Thanks - this is the kind of information that I was looking for! It sounds
like you're using vtc to bridge into Argonne. I presume when you say 'the
port number that comes up in the vic' you mean the ports that show up in
the command window as vtc is starting up? Is the third address an inbound
address also? It sounds like that's an outbound - or is there another
address+1 situation there as well? I'm trying to get some enlightenment
out of Bob Olson and others, but for some reason, it's like pulling teeth.
-randy
At 02:14 PM 10/24/2002 -0700, you wrote:
>Randy, although not a network person, I do live behind a restrictive
>firewall and use the Argonne bridge. During a normal session, we have to
>provide three port numbers to the network folk for them to open. The first
>is the port number that comes up in vic on the display machine. The second
>number is one number higher than the vic number (this is the port that the
>remote site window names travel on). The third is the number that our video
>machine vic uses to send our video.
>RAT and DPPT (client, not master) work just fine, with no firewall
>modifications. Opening the ports is only for receiving data. The video
>machine can broadcast our video through the firewall, but the unicast data
>coming back doesn't match up with any requests the firewall knows about, so
>it is blocked by default.
>By the way, the port numbers for the venues on the Argonne bridge change
>each time the bridge software is restarted, so we connect to the room early,
>get the numbers, and hope it doesn't have to be restarted before the meeting
>(this is why you might see PNNL videos in a room hours before meeting time).
>Hope this helps,
>~Ian
>Sent: Tuesday, October 22, 2002 4:04 PM
>To: ag-tech at mcs.anl.gov
>Subject: Re: [AG-TECH] Ports used in AG - part 2
>Thanks for the info that all of you have supplied. I still have one
>question that hasn't been answered, though. How many tools, clients, etc.
>that are used in AG are 'port shifters'? That is, how many respond on a
>different port from the port on which the incoming request was made? Is
>this information anywhere to be had?
>Most important to me right at the moment, is the action of the Argonne MSB
>(source not available) and not having had any real-live experience with
>QuickBridge - it's action - specifically on both what a unicast client sees
>on the unicast side of the bridge.
>Thanks!!
>-randy
> At 08:55 AM 10/18/2002 -0500, Michael Miller wrote:
> >Randy,
> >The vv.dat file included with the quickbridge contains a list of all the
> >IP's and ports used for the various ANL venues. I'm not sure how up to
> >date that is, but it's a good place to start. Also the IP's and ports
> >used on NCSA's venues server can be found here:
> >http://agschedule.ncsa.uiuc.edu/venues.asp
> >Beyond that there is VNC and DPPT, and perhaps RPPT. Also any polycom
> >addresses you want to link with will need to be opened.
> >Michael Miller
> >NCSA
> >At 03:01 PM 10/17/2002 -0700, you wrote:
> >>I'm faced with having to detail the ports used in AG work to our network
> >>folks who have decided that our present external connection, which is
> >>getting upgraded, needs a port filter applied. I BELIEVE, but I haven't
> >>verified, that this box is smart enough that we don't have to detail all
> >>the ports from which we will be originating transmissions, but incoming
> >>ports that don't correspond to outgoing ports are an unknown for me. Is
> >>there a document, or some collected wisdom, that I can tap?
> >>Unfortunately, I don't think that 'leave all the ports open' is going to
> >>be accepted as a valid answer.
> >>Thanks!!
> >>-randy
> >Thanx,
> >Michael Miller
> >System Engineer
> >Visualization Technology Support
> >Computing and Data Management
> >National Center for Supercomputing Applications
> >University of Illinois - UC
> >"If you're clear in your vision and trust the people in your team with
> >clear objectives, they will invariably do their best to achieve everything
> >desired, and usually deliver everything you could have hoped for and even
> >more." -Paul Debevec
