[AG-TECH] running point-to-point
Deb Agarwal
DAAgarwal at lbl.gov
Fri Oct 4 12:26:45 CDT 2002
To run the tools in unicast mode, run them from the command line
and specify the ip address of the machine you want to connect to.
The port should be even numbered and the same at both ends. So,
if two sites with ip addresses A and B respectively want to unicast
connect on vic and rat, an example set of command lines would be:
at Site A
vic B/6544 &
rat B/6546 &
at Site B
vic A/6544 &
rat A/6546 &
(where 6544 and 6546 are the ports the tools will run on)
Deb
Jennifer Teig von Hoffman wrote:
> Hi everybody,
> I can't recall how to run vic and rat point-to-point. Could somebody
> refresh my memory, or send me an URL with some info? In particular I
> can't remember how to know what ports to use.
> Thanks in advance,
> Jennifer
Deb Agarwal e-mail:DAAgarwal at lbl.gov
MS50B-2239 phone :(510)486-7078
Lawrence Berkeley National Lab URL: http://www-itg.lbl.gov/~deba
Berkeley, CA 94720
