[AG-TECH] Rtpmon Problem
Michael Daw
mike.daw at man.ac.uk
Tue Oct 29 08:27:02 CST 2002
OS is RH7.2.
I had to do a number of frigs to run ./configure "successfully" (because
this expected tcl no later than 7.6). After that, make gave me lots of
errors - that's when I gave up.
--Mike
> -----Original Message-----
> From: Robert Olson [mailto:olson at mcs.anl.gov]
> Sent: 29 October 2002 12:18
> To: Michael Daw; AG Technical Developers
> Subject: Re: [AG-TECH] Rtpmon Problem
> At 11:29 AM 10/29/2002 +0000, Michael Daw wrote:
> >I'm trying to run rtpmon.
> >I installed it from Bob's rpm (thanks, Bob - I was getting
> nowhere fast with
> >the non-rpm version!).
> >However, when I try to run it, it comes up with a dialog box
> saying 'Error
> >in Tcl script - Unknown color name ""'. Before I can hit any of
> the buttons
> >'OK / Skip messages / Stack trace', it crashes with a Segmentation fault.
> >Does anyone have a solution/workaround?
> Hm. I'd always been plagued with that error, but never got the segfaults.
> What OS is this on? Wonder if there's some shared lib incompatibility or
> something ...
> The compile from source was failing for you?
> --bob
