[AG-TECH] electronic whiteboards
Ulrich Schwenn
schwenn at rzg.mpg.de
Tue Oct 22 11:49:16 CDT 2002
Hi Cindy,
I am not (yet) an AG user but prefer commercial H.323 equipment.
For your problem that does not matter.
We set LaTex to produce a PS file which we then split with gs
(ghostscript) and appropriate parameters into straight numbered jpeg
files. These you can import to PowerPoint with an simple to write macro
you have to write once in visual basic (directly from PPT).
As for the notes, look up on the smarttechnology pages a new piece
called sympodium. This is a 15" flat touchscreen with the full
functionality of a standard smartboard, which your prof could use
alternatively. One can write and draw on slides, store those modified
slides in a new PPT or slide by slide.
For the distribution we use tightVNC, but probably you could arrange the
AG PPT tool to do this for you. If you have smarts on all sites you
should be able to use that whiteboard from both or multiple sites.
Have fun
Ulli Schwenn
Dr. Ulrich Schwenn
Head of Multimedia and Videoconferencing Group
Computing Center Garching
Max-Planck-Gesellschaft &
Max-Planck-Institut für Plasmaphysik
Boltzmannstr. 2, D-85748 Garching
GERMANY
Phone: +49 89 3299 1371
Fax: +49 89 3299 1301
e-mail: schwenn at rzg.mpg.de
web: http://www.rzg.mpg.de
Cindy Sievers wrote:
> Has anyone used an electronic whiteboard on the Access Grid to share
> notes?
> What are the issues associated with this? What other alternatives are
> there? We are going to do a class over the grid and the instructor
> wants to be able to annotate and write notes on a whiteboard for
> remote and local students to see. He would really prefer to write on
> his slides (which are in LaTex and need to be converted to PowerPoint
> - another issue - is this possible?). Any suggestions?
> Thanks!
> Cindy Sievers Los Alamos National Laboratory
> sievers at lanl.gov Group CCS-1 MS B287
> tel:505.665.6602 Advanced Computing
> fax:505.665.4939 Los Alamos, NM 87544
