[AG-TECH] event server seg fault
Jeff Long
long at ukans.edu
Fri Oct 18 16:09:15 CDT 2002
I think Brian is on the right track as I noticed similar problems
(arm/vrm-eventlistener crashes when changing rooms) after the last glibc
update. I believe I've solved my problem by replacing
/usr/local/ag/jre-1.2.2 (keep a copy!) with jre 1.2.2_013 from
http://java.sun.com/products/jdk/1.2/download.html.
Jeff Long
Brian Corrie wrote:
> Marcia,
> We recently saw something like this after upgrading some of the RH software.
> We think it was an upgrade to the glibc libraries that caused the problem -
> not sure if we have solved it or not... Did you upgrade your system lately???
> Brian
>>-----Original Message-----
>>From: Marcia Perry [mailto:mperry at lbl.gov]
>>Sent: Thursday, October 17, 2002 2:04 PM
>>To: ag-tech at mcs.anl.gov
>>Subject: [AG-TECH] event server seg fault
>>Hi,
>>Both arm-eventlistener and vrm-eventlistener are seg faulting
>>w/ error msg like:
>> vrm-eventlistener: line 21: 30166 Seg Fault \
>> $JAVA ag.VideoResourceManager --eventURL \
>> $EVENT_SERVER_URL --cacheURL $CACHE_URL $*
>>I tried killing everything and restarting all the ag s/w
>>with no luck. Can anyone please advise?
>>Thanks,
>>-- marcia
>>Marcia Perry MPerry at lbl.gov
>>Lawrence Berkeley National Laboratory WORK# (510) 486-6786
>>1 Cyclotron Road FAX# (510) 486-6363
>>Berkeley, CA 94720 MS: 50A-3111
