[AG-TECH] ddvic error
Rabarison Monika Klara
monika.k.rabarison at ccaix.jsums.edu
Wed Nov 6 12:13:06 CST 2002
It says "ddvic has encountered an error. Windows will close the program.
You need to restart the program." I have been in the Institution Lobby for
the last 10 minutes and everything is fine there.
Monika
On Wed, 6 Nov 2002, Robert Olson wrote:
> Hmmmm. Someone here mentioned that error as well.
> Does it look like an error message that came from ddvic itself?
> At 10:58 AM 11/6/2002 -0700, Darin Oman wrote:
> >Yes! I've had that error a few times over the last few days. It would
> >mostly happen when I moved from the lobby to the test room. I thought it
> >was a local problem (I deleted ag/agapps/bin directory and reinstalled
> >display software and have had the error only once since) but now I'm not
> >so sure. Is something on the network causing the error? Is there a bug in
> >the software (I'm running AG 1.2)? I, too, would like to get this figured out.
> >Darin Oman
> >NCAR
> >Rabarison Monika Klara wrote:
> >>Hello,
> >>Have anybody met the same problem as I have now in the lobby?
> >>Error on the display machine: "ddvic error, you need to restart
> >>the program..". I went to JSU venue and everything is fine.
> >>Any hint?
> >>Monika
> >>Monika Rabarison
> >>System Administrator
> >>HPVCI
> >>Jackson State University
> >>Office:(601)979-5933
> >>SciVis Lab:(601)979-1061
> >>jsuVisNode:(601)979-1056
Monika Rabarison
HPVCI
