[AG-TECH] DPPT (PowerPoint) audio
Tom Coffin
tcoffin at ncsa.uiuc.edu
Fri May 3 14:12:13 CDT 2002
you could duplicate the slide... so that on the mouse click it advances to
the next slide which is a slidecopy and have the sound triggered
automatically. this will hold the appearance of one mouse click per event.
__________________________________________
At 09:54 AM 5/3/2002 -0500, He, Yuan wrote:
>Even there's soundcard installed, DPPT will not play an audio file.
RPPT, on
>the other hand, can playback an embedded audio, but it must be set in the
>auto-start or timer-triggered mode (so that RPPT can start the playback by
>emulating a mouse-click event). The reason for the restriction in either
>DPPT or RPPT is because there's no way to detect or control the
>play/stop/pause of an embedded media file via PowerPoint OLE/COM
interface.
>Please correct me if I'm wrong :)
>Yuan (Eric) He
>Chemical and Petroleum Engineering Dept.,
>The University of Kansas,
>4006 Learned Hall, Lawrence, KS 66045, USA
>Tel: 785-864-2937
>Fax: 785-864-4967
>E-mail: heyuan at ku.edu
___________________________________________________________
Tom Coffin .......................... tcoffin at ncsa.uiuc.edu
