[AG-TECH] KVMs for AG?
    Paul B. Huang
    pbhuang at bmrc.berkeley.edu
    Fri May  3 14:04:25 CDT 2002
At Berkeley, we use Exceed and X11-forward, which is almost the same as
VNC.  It works really well, since we don't usually have to touch the KVM
at all during the meetings.  The most important tool to see via
X11-forward is probaly the rat tool on the audio machine.
--Paul
On Fri, 3 May 2002, Rob Ellison-Potter wrote:
> Has anybody had some positive experiences using VNC as a work around to
> this. I.E., VNC to your other machines so you don't have to use the KVM.
> thanks,
> rob
> Robert Ellison-Potter
> Jr. Network Administrator
> SC-31 US Dept of Energy
> rellisonpotter at er.doe.gov
> 301-903-3080
> From: "Mike Weaver" <weaver at er.doe.gov>
> To: "Don Morton" <morton at cs.umt.edu>; "Tom Coffin" <tcoffin at ncsa.uiuc.edu>
> Cc: <ag-tech at mcs.anl.gov>; <bernholdtde at ornl.gov>
> Sent: Wednesday, April 03, 2002 11:32 AM
> Subject: Re: [AG-TECH] KVMs for AG?
> > The Belkin manual mentions (in small print) in a couple of places not to
> > move the mouse or use the keyboard when switching channels and that the
> > mouse will be unresponsive for 1-2 seconds after a switch.  We try to be
> as
> > careful about this as possible!  It also states not to use the keyboard or
> > mouse on the active channel if the computer is booting as this can cause
> the
> > computer not to see the device.
> > That being said, I can reboot a working machine on channel 1, switch to
> > channel 2, wait exactly 5.2371 seconds, work on channel 2 for a while then
> > switch back to channel 1.  Wait another 5.2371 seconds and find that the
> > keyboard (or sometimes mouse) doesn't work.  I know that mouse
> > synchronization in particular is a very difficult problem for KVM
> switches,
> > but I do not see these kinds of problems on other brands ( we also use
> Rose
> > and Avocent/Cybex).
> > Mike
> > From: "Don Morton" <morton at cs.umt.edu>
> > To: "Tom Coffin" <tcoffin at ncsa.uiuc.edu>
> > Cc: "Mike Weaver" <weaver at er.doe.gov>; <ag-tech at mcs.anl.gov>;
> > Sent: Wednesday, April 03, 2002 9:49 AM
> > > Tom Coffin wrote:
> > > > I have noticed that with these switches they somtimes
> > > > freeze the mouse and keyboard if you are sending mouse
> > > > commands while switching.
> > > > I was recently putting our switch through some rugged testing
> > > > and figured that I really need to be patient or use a
> > > > slower process while switching. I now make sure that I am not
> > > > touching the mouse while switching. Let me know if the mouse
> > > > and keyboard still freeze while trying this movement.
> > > > Not a solution - but a workaround...
> > > yep, completely unscientific analysis and fix but, same
> > > situation here :)  i've found that it takes a few seconds
> > > for the electrons to switch between two machines and, once
> > > i actually do the keyboard switch, if i wait about
> > > 5.2371 seconds, then i can usually start moving the mouse
> > > without having things freeze up on me.  so, i'm being
> > > sarcastic but, it IS true that just waiting several
> > > seconds before moving the mouse typically reduces the
> > > chance of a freeze up.
> > >    Don Morton                   http://MRoCCS.cs.umt.edu/~morton/
> > >    Department of Computer Science       The University of Montana
> > >    Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
