[AG-TECH] VIC on display machine
    Nolan, Kevin [NCSUS]
    knolan at ncsus.jnj.com
    Wed May  1 07:05:29 CDT 2002
I was able to install the OpenGL drivers from the NVidia Website which
improved the performance of the Nvidia cards.  Before the drivers were
installed I could run about 5 - 7 windows before freezing - now I have about
15-20 windows open with no hanging.
-----Original Message-----
Sent: Monday, April 29, 2002 9:34 AM
To: ag-tech at mcs.anl.gov
Subject: RE: [AG-TECH] VIC on display machine
Unfortunately, we run AG-Ware on a seperate machine.  Anyone else out
there have trouble with the latest release of the nvidia drivers (ver
28.32)?  I can't seem to get them to 'stick' either.  Also, what
versions of DirectX is everyone running?
Thanks for all the help so far!
-Mike
> Just a thought - you're not running the AGware software on the
> same machine are you?  We do, and if we don't set the priority of
> AGware right down, it kills the performance of vic.  (Someone
> was kind enough to tell us the means of doing this - Task Manager,
> Processes tab, right click on process, Set Priority, Low).
> Cheers
> Chris
> ____________________________________________________________________
> Chris Osland                         Office tel: +44 (0) 1235 446565
> Digital Media and Access Grid      Medialab tel: +44 (0) 1235 446459
> BIT Department             Access Grid room tel: +44 (0) 1235 445666
> e-mail:   C.D.Osland at rl.ac.uk               Fax: +44 (0) 1235 445597
> CLRC Rutherford Appleton Laboratory (Bldg. R18)
> Chilton, DIDCOT, Oxon OX11 0QX, UK
> [The contents of this email are confidential and
> are for the use of the intended recipient only.
> If you are not the intended recipient do not take
> any action on it or show it to anyone else,
> but return this email to the sender and delete your copy of it.]
> From: Michael Gates [mailto:mgates at SDSC.EDU]
> Sent: 26 April 2002 18:38
> Subject: [AG-TECH] VIC on display machine
> I'm having a lot of trouble with VIC on my display machine.  It is
pegging
> the cpu and is unresposive to moving of windows (the video in each
window
> still shows and moves).  I have had this problem with both vic and
ddvic.
> My display machine is a Windows PC, and I have this same problem in
both
> Windows 2000 and windows XP on both PIII and P4 machines.  The video
cards
> I am running are Geforce2 Mx400s (pci) and Either an integrated ATI
or an
> AGP Geforce2 256.
> This problem makes it impossible for me to setup a display wall and
change
> views for different presenters.
> Any ideas out there in AG land?
> Thanks,
> -Michael Gates
> SDSC
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020501/83cc8d2a/attachment-0001.htm>
