[AG-TECH] Wide-angle camera
Jay Beavers
jbeavers at microsoft.com
Tue Jun 11 21:18:39 CDT 2002
An interesting paper in this area can be found at:
http://www.research.microsoft.com/~yongrui/ps/acmmm01.doc
- jcb
-----Original Message-----
From: Ivan R. Judson [mailto:judson at mcs.anl.gov]
Sent: Tuesday, June 11, 2002 3:54 AM
To: 'Osland, CD (Chris) '; darin at ucar.edu; 'Ag-Tech Mailing List
(E-mail)'
Subject: RE: [AG-TECH] Wide-angle camera
Hey,
This is a good plan. I was chatting the other day about this and we
were discussing that in a well designed room, that isn't "moved around"
a lot, you can probably use a single pan/tilt camera if the other 3 (now
"fixed") cameras are carefully selected for lens/placement/zoom.
This might also alleviate some of the human factors (STOP MOVING THAT
CAMERA :-).
--Ivan
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On
Behalf Of Osland, CD (Chris)
Sent: Tuesday, June 11, 2002 4:26 AM
To: 'darin at ucar.edu'; Ag-Tech Mailing List (E-mail)
Definitely a good idea, IMHO. I'm thinking of putting a couple of fixed
(no remote pan, tilt, focus, zoom) cameras with wide angle lens (nearly
fish-eye) at each end of our room. The one above the videowall will
show the whole audience, so node ops can arrange closer-up views in
correct order and see the overall picture if required. The one behind
the audience will give an overall view of what's on our videowall - this
has been invaluable in many situations, not least with shared
visualizations (Iris Explorer,
etc..) when VNC gets you a high quality picture there slowly and video
gets you a lower quality picture there almost immediately.
My reason for thinking of fixed cameras is that it's already a pain
having 4 remote-controlled cameras on 3 channels - having 6 on 3
channels would be even worse. I'm going to investigate CameraLink
cameras in case they happen to solve the problem.
Cheers
Chris Osland
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and
are for the use of the intended recipient only.
If you are not the intended recipient do not take
any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
Sent: 10 June 2002 22:56
To: ag-tech at accessgrid.org
Subject: [AG-TECH] Wide-angle camera
Hello,
We are entertaining the idea of placing a camera, possibly with a
wide-angle lens at the center of our AG room to get a nice, full view of
the audience. Does anybody have any experience and/or thoughts as far as
what type of camera we should purchase or even if this is a good idea?
Darin Oman
