[AG-TECH] Audio losses synch (more technical questions)
Robert Olson
olson at mcs.anl.gov
Mon Jun 10 07:49:13 CDT 2002
We typically don't run with lipsynch activated between rat & vic (reasons
include the necessity to play with .mbus files to get the synchronization
to work properly between audio and display machines, the fact that vic's
synch support is indeed out of synch with the support in rat, and that when
on a good-quality network, the casual synchronization resulting from
best-effort transmission results in "good-enough" lipsynch).
All that being said, if you get this working that'd be great, and we should
look at integrating the fixes.
>At the moment this would not be enough to fix a standard AG node, if audio
>and video sources are from different machines the cnames will not match
>anyway as these are derived from the IP address.
We've had some other discussion lately about changing the AG stuff to
define CNAMEs on a per-node rather than per-host basis.
>I managed to compile up the AG vic code linked against the most up to date
>UCL common library. (There is some new crypto code that has been
>seperatly added to both development trees but if you delete the files
>from vic the program still links ok)
An aside on why this is there - vic doesn't use the libcommon mechanisms
for RTP transport (it has its own internal RTP handling code). The crypto
code that's in libcommon is there in support of rat (and other clients of
the libcommon RTP library). Vic has analagous crypto code in a module
conforming to the vic crypto interface.
> This might be enough to fix this
>problem. It should be as all the mbus code would be from the same
>revision.
Did you see any weirdness with vic built with the latest libcommon? if not,
we can go ahead and merge the new libcommon in with vic.
Did you use the CVS version, or the latest release version (1.2.8). Ivan
found some win32 portability problems in the latest CVS version; not sure
of the state of resolution of those.
--bob
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020610/3aa41be7/attachment.htm>
