[AG-TECH] vic and Logitech QuickCam 3000 Pro on Linux
Don Morton
morton at cs.umt.edu
Tue Jul 9 13:23:00 CDT 2002
Gary Refka wrote:
> Don,
> I've gotten this to work with pretty much the same setup but using OpenMash
> VIC. Works fine. As far as I know the 2.8 UCL code does not support USB in
> Linux. Since Linux is just supporting the cameras in 7.3, barely, and the
> UCL code is a little long in the tooth this makes sense.
> Hope this helps some.
> Gary A. Refka
> Director of Engineering Operations
> INSORS Integrated Communications, Inc.
Gary, you are WAY COOL!!!! You are my hero of the day!!! It worked
like a charm - 5 minutes of work and I'm up and running, and your
explanation makes sense!! Thanks so much!
Don
Don Morton http://MRoCCS.cs.umt.edu/~morton/
Department of Computer Science The University of Montana
Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
