[AG-TECH] Logitech QuickCam 3000 Pro
Don Morton
morton at cs.umt.edu
Sat Jul 6 19:45:11 CDT 2002
Howdy,
I'm wondering if anybody has had experience in getting the Logitech
QuickCam 3000 Pro to work with vic on a Linux machine. Here's
what I'm using
RedHat 7.3 (kernel 2.4.18-3)
vic 2.8ucl-1.1.3-AG
I followed some great instructions, available at
http://www.isthe.com/chongo/tech/comp/pwc/rh7.3.html
for setting it all up, culminating in the use of "camstream"
to test the drivers and camera, and all worked - I'm able
to capture images from the web cam.
However, when I try to capture these using vic, the camera and all
is recognized but, when I try to actually TRANSMIT via the Logictech
camera, I get a bunch of ioctl errors indicating incorrect parameters
being used. Appended to this message is the output of running vic.
As you can see, vic finds both the Hauppauge and assigns to
/dev/video0 and the Logitech and assigns to /dev/video1.
The Logitech USB cam is selected in my device and then I try
to transmit - A thumbnail appears in vic, but with no image, then
I start getting all the ioctl invalid argument errors. I've played
with virtually every button on vic, and I've even played around a lot
with arguments to the pwc module using documentation from
http://www.smcc.demon.nl/webcam/install.html#param
However, it's been mostly trial and error with no real knowledge of
what I'm doing. Is anybody familiar with these issues? It appears to
me that vic is supplying arguments that either the kernel or, more
likely, one of the loadable modules (pwc) can't quite deal with????
Don
Don Morton http://MRoCCS.cs.umt.edu/~morton/
Department of Computer Science The University of Montana
Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
[root at kluane pwc]# vic -t 127 224.2.177.155/55524
V4l: trying /dev/video0... ok, BT878(Hauppauge (bt878))
V4l: color; size: 48x32 => 640x576 (scales)
V4l: ports: Television Composite1 S-Video Composite3
V4l: depth=16, palette=yuv422P
V4l: ==> format { 411 422 cif } size { small large cif } port { Composite1
Television S-Video Composite3 } type {ntsc auto pal secam}
V4l: trying /dev/video1... ok, Logitech QuickCam 3000 Pro
V4l: color; size: 160x120 => 640x480
V4l: ports: Webcam
V4l: depth=24, palette=yuv420P
V4l: ==> format { 411 422 cif } size { small large cif } port { Webcam } type
V4l: trying /dev/video2... open: No such device
V4l: trying /dev/video3... open: No such device
Got grid width 3
invoke init fonts
in init_Fonts
in lnonwindows section
using colormodel truecolor/24
Got grid width 3
enable=
Did not find monitor list
Using monitor list {0 0 1024 768 main 0}
have monitor 'idx=0' '0 0 1024 768 main 0'
v4l: mmap()'ed buffer size = 0xe1000
Got pict, palette=15
ioctl VIDIOCSPICT: Invalid argument
Got pict again, palette=15
ioctl VIDIOCMCAPTURE even: Invalid argument
ioctl VIDIOCMCAPTURE odd: Invalid argument
ioctl VIDIOCSYNC: Invalid argument
ioctl VIDIOMCAPTURE: Invalid argument
