[AG-TECH] Vidcap machine oddity
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Mon Jul 1 05:26:45 CDT 2002
I guess it has become so familiar I hadn't thought to mention it.
We see it on the display machine (see below).
I always see the same, but I do the following (to avoid any
stop-all/start-all, or venue change, hiatus):
1. click on a thumbnail in vic on display machine; this brings
up a medium size image;
2. slide this image somewhere!;
3. go back to the vic thumbnail window; this causes everything
to resolve itself miraculously!
I only ever do this on the display machine; to be honest I never
look at the video capture machine unless I have to run through
the bridge and so have to set NTSC -> PAL, datarate up, frame rate
up, etc... Possibly the same happens on the capture machine as
on the display machine, but I've never looked.
I just put it down as a feature, not a bug!
Cheers
Chris
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and
are for the use of the intended recipient only.
If you are not the intended recipient do not take
any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: Marty Hoag [mailto:Marty.Hoag at ndsu.nodak.edu]
Sent: 28 June 2002 20:13
To: James Miller; ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Vidcap machine oddity
James Miller wrote:
> The very first time I run vrm-eventlistener and enter a room, my camera
view
> displays what looks to be windows from the vidcap machine instead of the
> camera output. If I stop all and start all, my cameras become active.
> After that, I can enter other rooms, or even close the VRM and restart and
> my cameras are fine. If I logout and reboot the vidcap machine, I get the
> same problem until I again click on stop all and start all.
> Any ideas?
> Jim
I think that is probably a feature in the AGiB stuff - I've seen it
on our system and other places have mentioned they see it too. I call
it the "random surprise start-up screen capture mode". ;-) Usually one
or two of our four vics will be doing the vic screen capture instead
of camera source.
But the good news is that as soon as you enter another room it clears
up. Not sure if it is a timing thing or what. Since we usually do go
to a room we've just lived with it.
Marty
