[AG-TECH] The AGN Minimum Requirements Document
Markus Buchhorn Markus.Buchhorn at anu.edu.au
Thu Feb 28 17:43:39 CST 2002
Nice work Ivan!
At 05:01 AM 26/02/2002 -0600, Ivan R. Judson wrote:
>As promised here is the document that described what an AG Node is.  Please
>read it over and provide feedback via ag-tech.
I agree with the other comments on the shopping list section at the end,
and won't repeat them. The Gentner requirement is one I'd still like to
test out, since our VC centre here has a superb arrangement for audio,
which is using a (non Gentner) box I haven't identified yet. I'll get some
more details.
One point though - the requirements on latency. Without identifying what
kind of latency you mean, I think it's not helpful. Can I suggest it would
be better to have "encoding and decoding" latencies, of the order you
suggest (maybe a factor of two smaller) and separately mention transport
latencies - which you can't in general do much about. Those of us in Oz are
stuck with the Pacific rtt to the US no matter how direct we go :-) (until
at least... http://www.satirewire.com/news/jan02/australia.shtml ). Photons
in glass will only go so fast :-(
The cumulative latency for each stream impacts on the user-interaction,
i.e. how smooth conversations go, and at high values this becomes a pain -
the interaction becomes more formal. However, most users can really "only"
impact the encode/decode latencies with better CPUs and add-on comp/decomp
hardware.
Cheers,
         Markus
Markus Buchhorn, Information Infrastructure Services,   | Ph: +61 2 61258810
Markus.Buchhorn at anu.edu.au, mail: CompSci,CSIT Bldg #108|Fax: +61 2 61259805
Australian National University, Canberra 0200, Australia|Mobile: 0417 281429
More information about the ag-tech mailing list
