[AG-TECH] problem connecting the bridge on Display
Supreeya Miller
Supreeya.Miller at usm.edu
Wed Feb 20 15:24:56 CST 2002
This is odd. I tried the vtc command for the Lobby room. It said no
meeting. Then I tried the test room. It is working fine on all 3 machines.
Can you tell me what just happened to me in the LuckyLabbrador and the
Lobby?
Supreeya Miller
System Administrator/Visualization Researcher/Access Grid Coordinator
High Performance Visualization Center
Center of Higher Learning
Building 1103
Stennis Space Center, MS 39539
Phone: 228-688-2190
Fax: 228-688-7454
E-mail:Supreeya.Miller at usm.edu
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
Behalf Of Robert Olson
Sent: Wednesday, February 20, 2002 2:40 PM
To: Supreeya Miller; ACCESS community
Subject: Re: [AG-TECH] problem connecting the bridge on Display
did it work on the other machines?
are you behind a firewall?
-bob
At 02:15 PM 2/20/2002 -0600, Supreeya Miller wrote:
On the Display machine, I ran the command
vtc LuckyLabradorRoom_video bridge-2.accessgrid.org [password]
The vtc program did not run and I got a message
stream socket open: Not owner
I tried this command also
vtc.exe LuckyLabradorRoom_video bridge-2.accessgrid.org
[password]
I got the same result as above.
I also make sure that c:\ag\agapps\bin is in the path.
Any suggest what I should do next.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020220/de4c711b/attachment-0001.htm>
