[AG-TECH] AG Echo problems
Robert Olson olson at mcs.anl.gov
Wed Feb 20 12:01:09 CST 2002
your gentner setup looks okay; you may be having a problem with hardware
loopback in your audio pc.
What sort of audio card do you have? Are you running the opensound.com
audio drivers? What is the output of these commands:
         cat /dev/sndstat
         /sbin/lspci
         /usr/lib/oss/ossmix
How clear is the echo -- does it sound like acoustic room echo, or hardware
loopback echo (if you've heard both you can probably tell the difference :-)
--bob
At 03:42 PM 2/20/2002 +0000, Ben Juby wrote:
>[apologies to everybody on the ETF-ACCESSGRID list if you have received
>this twice. Mike quite rightly pointed out that this would be more
>appropriate for the AG-TECH list]
>In an AG test session yesterday it appeared that we were causing some
>echo when we unmuted our mics and other sites spoke to us (the other
>sites said they could hear their own audio being fedback through our
>mics). We have so far been unable to determine why this is and we would
>welcome any suggestions as to what is going wrong.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20020220/4c16f1fd/attachment-0001.htm>
More information about the ag-tech mailing list
