[AG-TECH] FW: VRVS/AccessGrid Integration (fwd)
Osland, CD (Chris)
C.D.Osland at rl.ac.uk
Fri Feb 1 11:30:04 CST 2002
Here are some notes that were sent to me a long time ago. They
may now be way out of date, but I thought I'd pass them on as
they have quite a few URLs thart may now have more up-to-date
information.
regards
Chris Osland
____________________________________________________________________
Chris Osland Office tel: +44 (0) 1235 446565
Digital Media and Access Grid Medialab tel: +44 (0) 1235 446459
BIT Department Access Grid room tel: +44 (0) 1235 445666
e-mail: C.D.Osland at rl.ac.uk Fax: +44 (0) 1235 445597
CLRC Rutherford Appleton Laboratory (Bldg. R18)
Chilton, DIDCOT, Oxon OX11 0QX, UK
[The contents of this email are confidential and
are for the use of the intended recipient only.
If you are not the intended recipient do not take
any action on it or show it to anyone else,
but return this email to the sender and delete your copy of it.]
-----Original Message-----
From: Alan J. Flavell [mailto:flavell at a5.ph.gla.ac.uk]
Sent: 24 July 2001 14:25
To: PPNCG private list
Subject: FW: VRVS/AccessGrid Integration (fwd)
This just arrived via the ESnet H.323 mailing list (I guess we'd get
to see it by other routes too, but anyhow...)
cheers
> From: Philippe Galvez [mailto:philippe.galvez at cern.ch]
> Sent: Tuesday, July 24, 2001 5:57 AM
> To: vrvs-announce at internet2.edu
> Subject: VRVS/AccessGrid Integration
> Dear Colleagues,
> This is an announcement about the integration of AccessGrid
> (www.accessgrid.org) in VRVS.
> As you know, VRVS (www.vrvs.org) technology gives the
> possibility to
> use either Mbone tools, H.323 clients or MPEG2 compression to perform
> multipoint videoconferencing. Today, we just released the AccessGrid
> integration to VRVS.
> You can access this functionality at:
> http://www.vrvs.org/accessgrid.html
> You can enter to a Virtual Venue and join a meeting
> either by using
> the Mbone tools or using and a H.323 client (*). For both cases, you
> will receive only one video stream. But, you have the possibility to
> select the video that you wish to receive by clicking on the "Video
> mode" icon. You can:
> o Set the display mode to "Selected Participants" and select from
> the participants list the video you want to see.
> o Set the display mode to "Browse Video" and then you see
> each video
> site in turn, selected in a "round robin" that switches from
> one site to
> the next according to a preset timer.
> Note that video and audio streams are sent in unicast to the
> corresponding VRVS/Accessgrid participant.
> Let us know if you want more information and just have comments
> Regards,
> Philippe Galvez on behalf of the VRVS team.
> o You can use the AccessGrid Mbone tools. You just need to copy
> the Accessgrid vic and rat in the VRVS2 directory which is
> created when
> you installed VRVS
> o H.323 video clients.
> + you will be able to see video if you use a Vic version
> that included the fixed bug for the h.261 encoding schema and the your
> H.323 client is able to send video (e.g. Netmeeting with a connected
> camera)
> + The AccessGrid node will be able to hear you
> but in order
> to have the H.323 client able to decode audio from a Virtual
> Venue, Rat
> should be set to PCM (uLaw) at 8 kHz (This is the standard in H.323
> I.T.U)
> (**) The gateway machine has been graciously provided by Bob Olson and
> Terry Disz at MCS/Argonne. Thanks for their support. The machine which
> runs the VRVS reflector performs the interface between the multicast
> cloud and the unicast streams that are sent to the particular machine.
> ---------------------------------------------------------vrvs-
> announce-+
> For list utilities, archives, subscribe, unsubscribe, etc.
> please visit the
> ListProc web interface at
> http://archives.internet2.edu/
> announce--
