[AG-TECH] IGMPv3, Source Specific Multicast, fully supported in Windows XP
Todd Needham
toddn at microsoft.com
Fri Aug 16 20:54:26 CDT 2002
If you want our compilers and a copy of XP for this, let me know.
-Todd
-----Original Message-----
From: Andrew Swan [mailto:aswan at cs.berkeley.edu]
Sent: Friday, August 16, 2002 5:17 PM
To: Tony Rimovsky
Cc: Ivan R. Judson; 'Robert Olson'; Jay Beavers; ag-tech at accessgrid.org
Subject: Re: [AG-TECH] IGMPv3, Source Specific Multicast, fully
Tony Rimovsky writes:
> http://bmrc.berkeley.edu/mhonarc/openmash-users/msg00345.html
> syntax is vic s,g/port and, as of June 2002, vic could only receive
> from one s,g pair.
just to clarify, we changed the syntax to be s at g instead of s,g.
if you grab a current binary or source release, you also need to
apply a patch from the mailing list although if you grab source
from our cvs repository that ought to work...
> Jay, that note also says "there is no version of winsock that supports
> ssm -- until then it can't be done on windows". given the information
> you have collected, this can probably work under xp.
we have neither ssm infrastructure nor an xp machine with
a suitable development environment available here but if
anybody is able to build mash with ssm support under xp i
would be interested in hearing about your experience and
would gladly commit any patches needed to make it work...
-Andrew
