[AG-TECH] New Node Install
Matthew Wolf
mwolf at cc.gatech.edu
Fri Aug 2 10:30:57 CDT 2002
I've had this problem as well. I got around it by putting links into
/usr/local/ag/lib that were named **8.0**, but pointed to the 8.3
libraries. You then write a wrapper script for reflector that adds
/usr/local/ag/lib to LD_LIBRARY_PATH.
It's not a very nice hack, but it does work.
Matt
"S.Booth" wrote:
> On Tue, 30 Jul 2002, Bob Olson wrote:
> > you can install a stock 7.3 redhat, and install the RPMs from
> > http://ag-tech.mcs.anl.gov/reldb/repository/releases/agib/snapshots/snap-006/
> > --bob
> The reflector RPM does not seem happy with redhat 7.3
> rpm -v -U
> http://ag-tech.mcs.anl.gov/reldb/repository/RPMS/i386/ucl-reflector-1.00-1.i386.rpm
> Retrieving
> error: failed dependencies:
> libtcl8.0.so is needed by ucl-reflector-1.00-1
> libtk8.0.so is needed by ucl-reflector-1.00-1
> 7.3 seems to install tcl 8.3 not 8.0 Other rpms installed fine.
> Stephen
> |epcc| Dr Stephen P Booth Project Manager |epcc|
> |epcc| s.booth at epcc.ed.ac.uk Phone 0131 650 5746 |epcc|
-- Matthew Wolf
-- Research Scientist, IHPC Laboratory
-- College of Computing, Georgia Tech
-- mwolf at cc.gatech.edu
