[AG-TECH] Matrox G200 Drivers Question
Russ Wolf
russ at bu.edu
Wed Sep 26 09:02:56 CDT 2001
One of my best moves was to toss the G200 card and replace it with
multiple G450 PCI cards.
If you want to experiment more with your G200 - try moving it to a
different slot. Because of the "plu and play" nature of Windows and the
way PCI works - you will see different performance from the locaiton of
the card on the PCI bus.
-Russ
John Shalf wrote:
> One thing that reduced the utilization is to use 16-bit
> color rather than 24bit. Aside from that, I have launch my
> VIC windows on the G400/AGP card in order to get around the
> CPU utilization problem (I'm running a 6-display system with
> a G200 and a G400). I'm very interested in any other tricks
> to reduce the CPU utilization.
> -john
> David Minor wrote:
> > Hi - we've been trying to isolate our CPU utilization problems on our Display machine, and think we've found them. I'm wondering if anyone has seen these or has suggestions?
> > We are running the G200 PCI card. We have been running with the latest Matrox drivers, which are dated January I believe (I'm not in front of the machine right now). The problem we have been seeing is that as soon as we open 3 windows in Vic, CPU utilization pops up to 50-60%, making for a very unpleasant experience.
> > Just for kicks (yeah right) I uninstalled the Matrox drivers and tried running with the M$ drivers that shipped with Win2k - guess what? Opening 3 Vic windows causes the CPU utilization to run at about 8-9%, which is great. We don't see 50% utilization until we open a lot of windows. Very acceptable behavior. Only problem is that you can't drag any of the windows over to the extended desktop on the projectors - they become corrupted. This is a known behavior and was expected.
> > So .. rock and a hard place here. Any suggestions?
> > BTW this is on a Dell GX300 system running a dual PIII 866.
