[AG-TECH] Mime-Version: 1.0
lujian
lujian at nlsde.buaa.edu.cn
Wed Sep 5 08:31:24 CDT 2001
Bob,
I cannot access /usr/share/doc dir on your ftp site.
and one more question, do you know how to add other charset support on moo server, such as simplified Chinese char?
We are now working on modifying Mitre CVW (http://cvw.sourceforge.net), we are trying to use CVW to better enhance AG-tool-sets group-awareness.
Thank you!
Lu Jian
National Lab of Software Development Environment
Beijing University of Aeronautics & Astronautics
P.R.C.
phone: 86-10-82317603
fax: 86-10-82317619
email:lujian at nlsde.buaa.edu.cn
在 2001-9-5 7:38:00 您写道:
>A prototype release of the new Virtual Venues server is now available.
>You will need a cleanly built RedHat 7.1 system. When you build it, ensure
>the following packages are installed:
> Web Server
> SQL Server
>For those that use KickStart, I have attached a KickStart configuration
>file that I use for building test machines. (You'll have to change the NFS
>build option to something appropriate to your site, of course).
>The RPMs are available at ftp://ag-tech.mcs.anl.gov/pub/vv/. Install all
>the .i386.rpm files:
> rpm -U -v <rpm filenames>
>You will find further installation notes in
> /usr/share/doc/ag-vv-1.0.00/INSTALL
>The primary purpose of this release is to shake out installation issues.
>There are some loose ends in the implementation as yet that will be fixed
>in the short term.
>You can report problems with the installation via the Bug Tracker at Source
>Forge. Go to http://sourceforge.net/projects/accessgrid and click on the
>Bugs link to get there. Set the category in the bug report to "Virtual
>Venue Server".
>thanks,
>--bob
