[AG-TECH] Multicast beacon questions
Satish Devarapalli
devasat at iit.edu
Tue Oct 30 12:50:05 CST 2001
hi Chris,
I have solved the problem, the error occurs when my program is connecting
to multicast session. In JMF2.0 the RTPSessionManager of 1.1 is moved to
RTPManager, i wrote a sample program which just connects to the multicast
session with RTPSessionManager and it fails, then later i changed to RTPManager
and program works fine, i am able to connect with out any problems. But
there are some more bugs, error occurs when i am trying to get the Feedback
Reports from the participants in the session. It works fine for some and
often it raises an exceptions. For the time being i am ignoring that report
and continuing with the rest. I will try to fix it soon.
Thanks
satish
-- Original Message --
>> with out logging in to the VirtualVenues i tried running this and i get
>> an error message "Cannot bind requested address",
>> after logging in i get "cannot bind:requested address in use"
>> i tried to trace the problem, this message is coming from RtpMonitor
code,
>> but couldnt figure out the exact cause for this exception.
>The problem is probably either:
>a) an app tries to bind a unicast udp socket to the session's specific
port,
>e.g. to send from (this is not necessary, since packets can be sent to
the
>session from any port) or
>b) there is/was a bug in the low level networking (e.g. native
>implementation of java.net.MulticastSocket) which was not setting the (BSD
>sockets) SO_REUSEADDR socket option (or equivalent), which allows other
>sockets to bind to (i.e. receive packets sent to) the same address.
>the (unix & windows) command line command 'netstat -a' will give an idea
>of
>what end points are bound on that machine.
>Chris
