[AG-TECH] Fwd: Mouse test
Michael Gates
mgates at SDSC.EDU
Thu Oct 11 17:40:54 CDT 2001
I have seen this same problem, but not associated with an omniview switchbox.
It happened when I only had a single keyboard, mouse, and monitor to go between
my two linux AG machines. The keyboard and mouse cables were indistinguishable
from each other and a couple times I accidentally plugged them in reversed
(mouse line into keyboard input, and vice versa). When I did this, and moved
the mouse, it hung the machine 90% of the time. I think the bug report should
go to Belkin to have them make sure that the ps2 lines don't get switched when
switching from one port to another.
On a Side note, I've noticed that the belkins behave much better when you take
your time with them (i.e., don't try to flip through the entire set of ports in
half a second).
Hope it helps,
-Michael
Michael Gates
Information Technology
Support and User Services
mgates at sdsc.edu
858.534.8369
mgates at pager.sdsc.edu
Room 265
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
Behalf Of Robert Olson
Sent: Thursday, October 11, 2001 2:40 PM
To: Jeff Olsen; ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Fwd: Mouse test
Can someone write this up as a bug and submit it to RedHat?
--bob
At 02:35 PM 10/11/2001 -0700, Jeff Olsen wrote:
>>X-Sender: gaunt at mail-lc.llnl.gov
>>X-Mailer: QUALCOMM Windows Eudora Pro Version 4.2.0.58
>>Date: Thu, 11 Oct 2001 13:57:29 -0700
>>To: Jeff Olsen <olsen11 at llnl.gov>, Jeff Olsen <olsen11 at llnl.gov>
>>From: "Ross Gaunt" <gaunt at llnl.gov>
>>Subject: Mouse test
>>All I can say is thanks for asking me to hang my linix machine.
>>As you may know, and may wish to pass onto AG-tech, I have a Belkin Omni
>>View Pro-4 KVM. I could not make it fail connected to my Windows 2000
>>machine, but in a flash my linix machine hung when I moved the mouse
>>quickly. On the linix machine the mouse vanished, I could not log in
>>remotely nor ping it.
>>I will see if I have a spare 4-port Raratin kvm.
>>Ross
>>K. Ross Gaunt gaunt at llnl.gov
>>Lawrence Livermore National Laboratory
>>PO Box 808, L-561 Voice: (925) 423-2533
>>Livermore, Calif 94551 FAX: (925) 423-8704
>Jeff Olsen
>7000 East ave, MS L-541
> Livermore, CA 94550
>(925) 423-1023
