[AG-TECH] Omnivew Matrix troubles
Charles Parks
cjparks at vpha.health.ufl.edu
Wed Oct 10 07:48:22 CDT 2001
When we first started having lockups, I moved all the node equipment over to an old Compaq switch we had lying around. For a week we ran without a single problem. Then we moved back to the Belkin, and within a day both the video and display machines were locked. Not conclusive, but certainly compelling...
Chuck Parks <cjparks at ufl.edu>
University of Florida
IT Center System Administration
1.352.392.3900
>>> Don Morton <morton at cs.umt.edu> 10/09/01 23:25 PM >>>
Very interesting - we've certainly had Linux machine lockups
that required hard reboot, and now and then I've had sporadic
behaviour out of the Belkin, but never related the two
problems.
I assume you've done something that absolutely convinces you
that the Belkin is the problem? The fact that Linux locks
up at all, of course, is something "different" as it tends
to be quite stable but, I figured maybe there was something
about the AG apps running on it that pushed it in ways that
other Linux machines don't experience.
Charles Parks wrote:
> Funny you should mention that -- we're having the same problem here. I was going to send ours back as defective and get another, but if other people are having similar problems perhaps we'll go with something else.
> If you're looking for suggestions, I've had good experiences with Cybex switches.
> 1.352.392.3900
> >>> Jeff Olsen <jeffo at llnl.gov> 10/09/01 15:22 PM >>>
> Hello,
> Anyone out there had problems with their keyboard and mouse freezing with
> the 2x8 matrix kvm switch? I have contacted Belkin with the only
> suggestions of not using Logitech drivers which I have removed with no
> success. I am using the switch with Dell systems. The Linux systems hang to
> the point where I cannot even ssh into them to do a graceful restart....scary.
> Thanks for any advice!
> Jeff
> Jeff Olsen
> Lawrence Livermore National Laboratory
> 7000 East ave, MS L-541
> Livermore, CA 94550
> (925) 423-1023
Don Morton http://www.cs.umt.edu/~morton/
Department of Computer Science The University of Montana
Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
