[AG-TECH] jaggy images
Lisa Childers
childers at mcs.anl.gov
Thu Oct 4 16:20:18 CDT 2001
if you look at the vic thumbnails, do you see loss (expressed as a %)? if
you mute all streams and you still see loss, it is network. if you mute all
streams and see the loss decrease, it is your cpu.
Lisa
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
Behalf Of Supreeya Miller
Sent: Thursday, October 04, 2001 4:06 PM
To: ACCESS community
Subject: [AG-TECH] jaggy images
All,
Windows on the Display machines display jaggy images. I've read the
newsgroup that people had some problem with the CPU utilization. How can I
check and reduce the CPU utilization? or the jaggy images are caused by
having bad network or overload traffic?
Spec on Display machine
Dual PentiumIII 866 Mhz/133 w/256K Cache
128MB RDRAM, 800MHz
30GB, IDE 7,200RPM, Ultra 100
Matrox G200 Multi-Monitor TV Tuner (Quad)
Any help would be appreciated.
Supreeya Miller
System Administrator/Visualization Researcher
High Performance Visualization Center
Center of Higher Learning
Building 1103
Stennis Space Center, MS 39539
Phone: 228-688-2190
Fax: 228-688-7454
E-mail:Supreeya.Miller at usm.edu
