[AG-TECH] Fwd: XAP800 and AP400 interoperability
Robert Olson
olson at mcs.anl.gov
Mon Oct 1 14:27:28 CDT 2001
I suspect one could do this to make the two boxes work in a room: Configure
one of the gentners as usual (call this G1). Attach one of the outputs of
G1 (call it OUT) on G1 to input A on the second one, call it G2. Configure
G1 with the echo cancellation reference set to OUT (routing the PC output
to that output). Route input A on G2 to an output (Say output D). Set the
EC ref on G2 to that output.
Set the gains on G1 OUT, G2 input A, G2 output D to 0 dB.
Now you may be able to use the twelve mic inputs without problem. Realize I
haven't tested this, but as I understand how the gentners operate I think
it may work.
--bob
At 02:16 PM 10/1/2001 -0500, Jonas Talandis wrote:
>info from Gentner......
>>From: Leslie Grant <Leslie.Grant at gentner.com>
>>To: "'jonast at evl.uic.edu'" <jonast at evl.uic.edu>
>>Subject: XAP800 and AP400 interoperability
>>Date: Mon, 1 Oct 2001 12:59:08 -0600
>>X-Mailer: Internet Mail Service (5.5.2653.19)
>>Hello Jonas,
>>The XAP800 and the AP400 do not work together. There are some enhancements
>>in the XAP800 that go beyond the capabilities of the AP400. If you would
>>like to contact me directly at 801-974-3652 we can discuss you current room
>>configuration and see if we can find some alternatives to work with the
>>current configuration.
>>Leslie Grant
>>Sales Coordinator
>>Gentner Communications
>>lgrant at gentner.com
>>801-974-3652 / 800-945-7730
