[AG-TECH] hiss from gentner AP800
Darryl Szymanski
darrylrs at imprintsys.com
Mon Nov 26 14:24:10 CST 2001
If I can be of help, I just so happen to be on the phone with a Gentner
Regional Director at the time you all posted this concern with the hissing??
Here is a ph # and contact name for Gentner Tech Support he provided me for
you.
Call: Leslie Grant at 1-800-945-7730, he specializes on AG/Gentner
troubleshooting.
Darryl R. Szymanski
Special Projects Coordinator/Sales
Imprint Systems, Inc.
1-800-433-4512
-----Original Message-----
Sent: Monday, November 26, 2001 1:57 PM
To: Stewart, Corbin J; 'James Miller'
Cc: Access Grid Tech (E-mail)
Subject: RE: [AG-TECH] hiss from gentner AP800
What sort of speakers do you have? If you have powered speakers, and there
is an error in the routing, if you have the gain turned up very high you
are likely to be generating some hiss.
I'd recommend going through the audio balancing steps at the end of the
audio tutorial at
http://www-unix.mcs.anl.gov/~olson/AG/AudioTutorial/AudioTutorial.htm
If you successfully go through all of these steps, your system should be
happy. If one of them fails, you will have pretty closely pinpointed the
problem you may be having.
--bob
At 12:48 PM 11/26/2001 -0700, Stewart, Corbin J wrote:
>We are also experiencing a hiss. We're using the AP400 with Analog
>MatchMaker.
>Like you we've traced all the connections and we are
>about to swap out the soundcard. We have the added problem that we cannot
>send
>audio. The genter's meters indicate that signal is being sent to the audio
>server
>but the RAT doesn't seem to see it.
>Sorry I don't have an immediate solution but I'll let you know if we get
rid
>of the
>hiss.
>Corbin Stewart cjstewa at sandia.gov
>Videoconferencing & Collaborative Environments
>Sandia National Laboratories California
>925-294-4856
>From: James Miller [mailto:millerjw at mailer.psc.edu]
>Sent: Monday, November 26, 2001 11:30 AM
>To: Access Grid Techs mailing list (E-mail)
>Subject: [AG-TECH] hiss from gentner AP800
>I am trying to resolve a major hiss problem with our AG node. I am getting
>a lot of hiss out of my monitor speakers. I think I have narrowed it down
>to a problem with the AP800. If I disconnect all of my inputs to the
>gentner, the hiss is still there. When I disconnect the speakers, the hiss
>stops. This tells me the hiss is not coming from cable interference to the
>speakers and it is not coming from the MatchMaker/Audio node. If I mute
all
>of my inputs, the hiss remains. If I mute the speaker output from the
>gentner, the hiss lessens, but does not disappear.
>Has anyone had similar experiences?
>Jim Miller
>Network Engineer
>Pittsburgh Supercomputing Center
>4400 Fifth Avenue
>Pittsburgh, PA 15213
>mailto:millerjw at psc.edu
>412.268.6073
