[AG-TECH] Re: AG video node using berkley mjpeg work
    José María González
    chema at cs.berkeley.edu
    Thu Nov 15 13:44:36 CST 2001
There are two places where we could insert lml33's
jpeg hardware processing, the encoding and the decoding
side.
On the encoding side, current codecs do both encoding
and packetizing of the resulting data. We could create
an alternative version of the MJPEG encoder so that it
accepts jpeg-encoded frames (as they are produced from
the lml33 card) and just does the packetizing (call it
"p-jpeg"). To make it work with vic, we would need
setting the VideoPipeline object so that the only codec
acceptable for the lml33 card in JPEG mode is "p-jpeg".
This solution would probably work, but in terms of
software architecture would be really dirty. The reason
is that the object that is passed from the capture
device to the codec, VideoCapture::frame_, is just a
generic byte pointer (u_char* actually). It is always
a component, 3-planar, YUV frame (chroma subsampling
depending on the codec). Using it on the "p-mjpeg" codec
as a a component, 3-planar, jpeg-encoded frame would
be at least disconcerting.
A cleaner, long-term solution would imply major changes
in vic's architecture, so that different frame types
(raw, MJPEG encoded, etc.) can be passed to the codec.
Including hardware decoding is a harder task.
-Chema
Matthew Delco wrote:
> I'd have to rea-read my sentence to see what I said.  vic can't currently
> take advantage of the lml33's hardware jpeg capability.  Prof. Rowe was
> the last/only person to work on this, and I think we all got a bit puzzled
> (at that time) by the video abstractions.
> I could write a mash driver that provides a hardware encoded image to
> mash, but beyond that I wouldn't know how to plug it into mash properly.
> FOr decoding, mash would have to hand the driver a complete jpeg (or some
> well-defined subset of one) that I could then kludge into a format that
> the lml33 would like.  However, only certain video sizes would work, and
> on prior occasions I've foudn that the lml33 doesn't like the jpegs that
> are produced by vic.  As far as I can tell, the lml33 is very picky about
> where the EOI marker is placed, and most vic images are a one or more
> bytes too large or small.  The IJPEG library makes a similar complaint,
> but proceeds without failing in a fatal manner.
> MD
