[AG-TECH] Re: AG video node using berkley mjpeg work
Bob Riddle
bdr at internet2.edu
Thu Nov 15 07:18:20 CST 2001
I'm using v5.1.6 - is there a "better" version I should get? I'm
guessing I'll need to use CVS & pull down & build the code.
Andrew Swan wrote:
> Bob Riddle writes:
> > If I set the mjpeg capture rate greater than 10 mbps the display machine
> > never saw the mjpeg stream. I don't understand why this is true.
> we've done a fair amount of work recently on the mjpeg decode
> and render path. the problems that we've been working on are
> mostly in the handling of large jpeg images (i.e., the images
> in a high bandwidth stream). you didn't mention which version
> of mash you were running although i'd be interested to hear if
> you saw any improvement with the latest version from the mash
> cvs repository.
> it could be that the frames are simply too large for the
> static sized buffers in the jpeg reassembly code -- you can
> check this by clicking on "info..." next to the thumbnail in
> the main vic window, then choosing "decoder stats" and looking
> a the "huge frame" statistic. again though, our changes from
> the last few weeks should address many of these problems.
> > On the Display machine (Win2K), when I expanded the mjpeg vic window,
> > the reported frame rate dropped from 30 fps to about 15-17 fps. The
> > data rate reported also dropped from 10 mbps to about 6-7 mbps.
> > However, the picture was great looking. I checked the CPU with task
> > manager & one processor was tapped out completely. My belief is if I
> > had a faster processor, I could have sustained higher frame rates.
> yeah, openmash (and i suspect all the other vics since they come
> from a common source base) doesn't degrade well when the display
> machine cannot decode and render all the video that's being
> received. your socket buffers just overflow while the cpu is
> hopelessly grinding away at jpeg decoding. that's why the
> reported bandwidth and frame rate drop.
> -Andrew
