[AG-TECH] FYI, IETF Best Practices document on multicast address allocation
Bob Olson
olson at mcs.anl.gov
Tue May 15 07:51:23 CDT 2001
http://www.ietf.org/internet-drafts/draft-albanna-iana-ipv4-mcast-guidelines-01.txt
4. Introduction
The Internet Assigned Numbers Authority (IANA) (www.iana.org) is
charged with allocating parameter values for fields in protocols
which have been designed, created or are maintained by the Internet
Engineering Task Force (IETF). RFC 2780 [RFC2780] provides the IANA
guidance in the assignment of parameters for fields in newly
developed protocols. This memo expands on section 4.4.2 of RFC 2780
and attempts to codify existing IANA practice used in the assignment
IPv4 multicast addresses.
The terms "Specification Required", "Expert Review", "IESG Approval",
"IETF Consensus", and "Standards Action", are used in this memo to
refer to the processes described in [RFC2434]. The keywords MUST,
MUST NOT, MAY, OPTIONAL, REQUIRED, RECOMMENDED, SHALL, SHALL NOT,
SHOULD, SHOULD NOT are to be interpreted as defined in RFC 2119
[RFC2119].
In general, due to the relatively small size of the IPv4 multicast
addresses space, further allocation of IPv4 multicast address space
is not recommended. Specifically, the IANA should only assign
addresses in those cases where the dynamic selection (SDP/SAP), GLOP,
SSM or Administratively Scoped address spaces cannot be used. The
guidelines described below are reflected in on
http://www.iana.org/cgi-bin/multicast.pl.
