[AG-TECH] Audio in receive mode?
Randy Groves
randy.groves at boeing.com
Fri Jun 1 15:56:53 CDT 2001
I found the reflector and installed it on my video box. I can get audio
output locally. But still no audio when I connect to one of the
venues. Is there any selection of stream/source that I need to do in the
RAT window in order to hear anything? I'm 'listening' (the 'listen' button
is engaged). I've tried all of the accessible rooms and the Lobby.
I might re-iterate that we're still having transmission problems on our
multicast. I can receive just fine, but no transmit so far. So if the
reception of audio depends on some transmission from my audio box, then
that may be a problem.
I haven't tried getting audio locally without the reflector - I'll give
that a try.
-randy
At 09:38 PM 5/31/2001 -0500, Marty Hoag writes:
> Do you know about the reflector? It would let you test audio locally at
>least. See
>http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/msg00039.html
>(The reflector has been included in some of the later builds that are in beta
>test but I'm not sure it was in the 0511 and besides, you generally run the
>reflector on the video machine as explained in Bob's mail).
