[AG-TECH] Linux networking problems
Robert Olson
olson at mcs.anl.gov
Wed Jul 25 16:11:55 CDT 2001
Have you tried using iperf (http://dast.nlanr.net/Projects/Iperf/) for the
bandwidth measurement?
--bob
At 04:06 PM 7/25/2001 -0500, Kay Gunn wrote:
> > I only know enough about this to be dangerous but are you sure the
> > switch port is full duplex?
>Our network admin just verified that it is full-duplex.
>This means either mii-diag gave me faulty information or I'm reading it
>wrong. Of course, I did use the very same switch port successfully with
>Redhat 7.1 forced to do 100MB full duplex, so if the port was set to
>half-duplex, I should have seen problems there, too.
>mii-diag output included the following:
> Speed fixed at 100 mbps, full-duplex. #that's my linux box/card
>Your link partner is generating 100baseTx link beat (no
>autonegotiation). #that's the switch
>I'm assuming that's 100BT HD fixed, since card info possibilities
>listed
>100baseTx-FD and 100baseTx.
> > if it is 100BaseT. The reason I ask is that I think the full duplex end
> > of a theoretical mismatch would never get a collision because it knows
> > you cannot get collisions running at full duplex. But the hdx end would
> > not
>That makes sense...but I would expect to see errors. I have never worked
>with Linux before, but I have worked alot with Solaris and 100BT duplex
>problems. In the past when I've seen a duplex mismatch on Solaris, I'd
>see *ALOT* of errors (using netstat -i time slices).
>The network admin looked at the port statistics on the switch I'm
>connecting to, and he is seeing alot of errors there (but no collisions)
>for my grid nodes. 99% of the errors are RUNTS, with a few CRC. It
>doesn't make sense to me that the switch is reporting the errors, but the
>linux boxes aren't (they're just performing slowly). I'll install Redhat
>7.1 back on one of machines that's generating the RUNTS to see if they go
>away with the different OS.
>Kay Gunn
