[AG-TECH] Linux networking problems
Kay Gunn
gunn at colltech.com
Wed Jul 25 13:21:54 CDT 2001
Thanks for the tip. I got this installed and running on my ag nodes.
One thing I really like about this tool is that you can suppossedly use it
to set as well as check your speed/duplex settings. And in case you're
wondering..I really don't care about ftp speeds. I had noticed some
network issues and was just looking for a way to benchmark the network
performance. I'm using ncftp which gives a nice avg after it finishes
downloading a file.
Here is the output from my station with the etherexpress pro 100 card.
I left this running while I was doing a large file transfer. The avg
again for the transfer was 2.66MB/sec.
[root at watrgrid3 /tmp]# ./mii-diag -v -w
mii-diag.c:v2.02 5/21/2001 Donald Becker (becker at scyld.com)
http://www.scyld.com/diag/index.html
Using the default interface 'eth0'.
Basic mode control register 0x2100: Auto-negotiation disabled, with
Speed fixed at 100 mbps, full-duplex.
You have link beat, and everything is working OK.
This transceiver is capable of 100baseTx-FD 100baseTx 10baseT-FD
10baseT.
Able to perform Auto-negotiation, negotiation not complete.
Your link partner is generating 100baseTx link beat (no
autonegotiation).
End of basic transceiver informaion.
MII PHY #1 transceiver registers:
2100 780d 02a8 0154 05e1 0081 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000
0a03 0000 0001 0000 0000 0000 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000.
Basic mode control register 0x2100: Auto-negotiation disabled!
Basic mode status register 0x780d ... 780d.
Link status: established.
Capable of 100baseTx-FD 100baseTx 10baseT-FD 10baseT.
Vendor ID is 00:aa:00:--:--:--, model 21 rev. 4.
No specific information is known about this transceiver type.
I'm advertising 05e1: Flow-control 100baseTx-FD 100baseTx 10baseT-FD
10baseT
Advertising no additional info pages.
IEEE 802.3 CSMA/CD protocol.
Link partner capability is 0081: 100baseTx.
Negotiation did not complete.
Monitoring the MII transceiver status.
13:57:25.518 Baseline value of MII BMSR (basic mode status register) is
780d.
> You can compile the mii diag tools yourself under RH 6.2,
> and it might well be rewarding. I just tried fetching from:
> which has instructions, and links to the necessary pieces:
> ftp://ftp.scyld.com/pub/diag/mii-diag.c
> ftp://ftp.scyld.com/pub/diag/libmii.c
> After fetching these, just say
> gcc -Wall -Wstrict-prototypes -O mii-diag.c -DLIBMII libmii.c -o mii-diag
> (quoting from the last couple lines of mii-diag.c) and then
> mii-diag -v -w
