[AG-TECH] Anybody available to help us doing multicast test and debugging?
Xing Li
xing at cernet.edu.cn
Sun Jul 22 07:41:32 CDT 2001
Thx Linda, the msdp peer with apan is not working at this moment.
i am waiting for reconfiguration which will be done by Yoshinori
Kitatsuji
<kitaji at kddlabs.co.jp>.
bj-igw-r0b>sh ip msdp sum
MSDP Peer Status Summary
Peer Address AS State Uptime/ Reset Peer Name
Downtime Count
203.181.248.242 7660 Down 00:00:11 17670
tpr2-atm0-0-0-5.jp.apan.net
210.25.129.240 9406 Up 22:17:07 3 ?
bj-igw-r0b>sh ip msdp co
SA State per ASN Counters, <asn>: <# sources>/<# groups>
Total entries: 5
9406: 5/4
bj-igw-r0b>sh ip msdp sa-
MSDP Source-Active Cache - 5 entries
(210.25.133.22, 224.8.8.1), RP 210.25.129.253, BGP/AS 9406,
23:15:10/00:05:13
(210.25.133.24, 224.8.8.1), RP 210.25.129.253, BGP/AS 9406,
23:15:10/00:05:13
(210.25.132.18, 224.0.1.24), RP 210.25.129.253, BGP/AS 9406,
00:07:36/00:01:13
(210.25.133.7, 224.2.177.155), RP 210.25.129.253, BGP/AS 9406,
00:05:52/00:05:13
(210.25.133.24, 233.2.171.1), RP 210.25.129.253, BGP/AS 9406,
23:15:10/00:05:13
bj-igw-r0b>
I would like to start multicast session with startap, after the apan
multicast
stablized.
best,
xing
Linda Winkler wrote:
> Lujian
> It appears that the multicast routers are being announced but MSDP
> is not working yet to announce SourceActive messages.
> Please run
> sh ip msdp sum
> sh ip msdp co
> thx, w
> At 04:32 AM 7/22/2001, lujian wrote:
> >AG-tech friends,
> > Our multicast seems to be opened, but we cannot receive any AG
> > data. see the following result of our tests,
> > our beacon is at 210.25.133.24.
> > I will be on AG mud, called lujian_lj.
> > Thank you very much!
> > We still can't receive Access Grid multicast data.
> > We have done some test, the result is listed below, hope to be
> > helpful for you to debug multicast routing.
> > these tests are done from Cisco 12008( 210.25.133.62)
> >test1
> >buaa-tgw-r5>mtrace
> >Source address or name: agaudio.osc.edu
> >Destination address or name: 210.25.133.62
> >Group address or name:
> >Multicast request TTL [64]:
> >Response address for mtrace:
> >Type escape sequence to abort.
> >Mtrace from 192.88.194.132 to 210.25.133.62 via RPF
> > From source (agaudio.osc.edu) to destination (?)
> >Querying full reverse path...
> > 0 210.25.133.62
> >-1 210.25.133.62 PIM/MBGP [192.88.194.0/24]
> >-2 210.25.129.30 PIM/MBGP [192.88.194.0/24]
> >-3 210.25.129.34 PIM/MBGP [192.88.194.0/24]
> >-4 210.25.128.5 PIM/MBGP [192.88.194.0/24]
> >-5 202.112.1.212 PIM [192.88.194.0/24]
> >-6 202.112.36.241 PIM [192.88.194.0/24]
> >-7 202.112.36.130 PIM/MBGP [192.88.194.0/24]
> >-8 tppr-atm1-0-0-11.jp.apan.net (203.181.248.114) [AS 7660]
> >-9 tpr2-atm0-0-0-2.jp.apan.net (203.181.248.234) [AS 7660]
> >-10 abilene-tpr2.jp.apan.net (203.181.248.133) [AS 7660]
> >-11 clev-ipls.abilene.ucaid.edu (198.32.8.26) [AS 11537]
> >-12 krc4-atm1-0-0s1.ohio-gigapop.net (192.88.192.34) [AS 3112]
> >-13 krc1-atm1-0-0s4.columbus.oar.net (192.88.192.70) [AS 3112]
> >PIM [192.88.194.128/25]
> >-14 osc1-atm0-0s1.columbus.oar.net (192.88.194.6) [AS 3112]
> >-15 agaudio.osc.edu (192.88.194.132)
> >buaa-tgw-r5>
> >test2
> >buaa-tgw-r5>mtrace
> >Destination address or name: 210.25.133.24
> >Group address or name: 233.2.171.1
> >Response address for mtrace: 210.25.133.62
> >Mtrace from 192.88.194.132 to 210.25.133.24 via group 233.2.171.1
> > 0 210.25.133.24
> >-1 210.25.133.62 PIM [192.88.194.0/24]
> >-2 210.25.129.30 PIM [192.88.194.0/24]
> >-3 210.25.129.34 PIM Reached RP/Core [192.88.194.0/24]
> >buaa-tgw-r5>
> >test3
> >buaa-tgw-r5>mtrace
> >Source address or name: ws-video.mcs.anl.gov
> >Mtrace from 140.221.34.1 to 210.25.133.62 via RPF
> > From source (ws-video.mcs.anl.gov) to destination (?)
> > 0 210.25.133.62
> >-1 210.25.133.62 PIM/MBGP [140.221.0.0/16]
> >-2 210.25.129.30 PIM/MBGP [140.221.0.0/16]
> >-3 210.25.129.34 PIM/MBGP [140.221.0.0/16]
> >-4 210.25.128.5 PIM/MBGP [140.221.0.0/16]
> >-5 202.112.1.212 PIM [140.221.0.0/16]
> >-6 202.112.36.241 PIM [140.221.0.0/16]
> >buaa-tgw-r5>
> >test4
> >buaa-tgw-r5>mtrace
> >Mtrace from 140.221.34.1 to 210.25.133.24 via group 233.2.171.1
> > 0 210.25.133.24
> >-1 210.25.133.62 PIM [140.221.0.0/16]
> >-2 210.25.129.30 PIM [140.221.0.0/16]
> >-3 210.25.129.34 PIM Reached RP/Core [140.221.0.0/16]
> >buaa-tgw-r5>
> >test5
> >buaa-tgw-r5>mtrace
> >Source address or name: 210.25.133.62
> >Destination address or name: 192.88.194.6
> >Mtrace from 210.25.133.62 to 192.88.194.6 via RPF
> > From source (?) to destination (osc1-atm0-0s1.columbus.oar.net)
> > 0 osc1-atm0-0s1.columbus.oar.net (192.88.194.6)
> >-1 osc1-atm0-0s1.columbus.oar.net (192.88.194.6) [AS 3112] PIM [default]
> >-2 krc1-atm1-0-0s1.columbus.oar.net (192.88.194.5) [AS 3112]
> >PIM/MBGP [210.25.133.0/24]
> >-3 krc4-atm5-0-0s3.ohio-gigapop.net (192.88.192.69) [AS 3112]
> >-4 abilene.ohio-gigapop.net (192.88.192.33) [AS 3112]
> >-5 ipls-clev.abilene.ucaid.edu (198.32.8.25) [AS 11537]
> >-6 tpr2-atm-0-0-0-13.jp.apan.net (203.181.248.134) [AS 7660]
> >PIM [210.25.133.0/24]
> >-7 tppr-atm1-0-0-3.jp.apan.net (203.181.248.233) [AS 7660]
> >-8 cernet-tppr.jp.apan.net (203.181.248.113) [AS 7660]
> >-9 202.112.36.132 PIM [210.25.133.0/24]
> >-10 202.112.36.242 PIM [210.25.133.0/24]
> >-11 beijing-sgw.cernet.net (202.112.1.218) PIM/MBGP [210.25.133.0/24]
> >-12 210.25.128.6 PIM/MBGP [210.25.133.0/24]
> >-13 210.25.129.33 PIM/MBGP [210.25.133.0/24]
> >-14 210.25.129.29 PIM [210.25.133.0/26]
> >-15 210.25.133.62
> >test6
> >buaa-tgw-r5>mtrace
> >Source address or name: 192.88.194.6
> >Mtrace from 192.88.194.6 to 210.25.133.62 via RPF
> > From source (osc1-atm0-0s1.columbus.oar.net) to destination (?)
> > 0 210.25.133.62
> >PIM [192.88.194.4/30]
> >-15 osc1-atm0-0s1.columbus.oar.net (192.88.194.6)
> >buaa-tgw-r5>
> >test7
> >buaa-tgw-r5>mtrace
> >Source address or name: 140.221.20.124
> >Mtrace from 140.221.20.124 to 210.25.133.62 via RPF
> > From source (stardust-msfc-20.mcs.anl.gov) to destination (?)
> > 0 210.25.133.62
> >test8
> >buaa-tgw-r5>mtrace
> >Destination address or name: 140.221.20.124
> >Mtrace from 210.25.133.62 to 140.221.20.124 via RPF
> > From source (?) to destination (stardust-msfc-20.mcs.anl.gov)
> > 0 stardust-msfc-20.mcs.anl.gov (140.221.20.124)
> >-1 stardust-msfc-20.mcs.anl.gov (140.221.20.124) [AS 683] PIM [default]
> >-2 kiwi.anchor.anl.gov (140.221.20.97) [AS 683] PIM/MBGP [210.25.133.0/24]
> >-3 abilene-anl.anchor.anl.gov (192.5.170.170) [AS 683]
> >-4 tpr2-atm-0-0-0-13.jp.apan.net (203.181.248.134) [AS 7660]
> >-5 tppr-atm1-0-0-3.jp.apan.net (203.181.248.233) [AS 7660]
> >-6 cernet-tppr.jp.apan.net (203.181.248.113) [AS 7660]
> >-7 202.112.36.132 PIM [210.25.133.0/24]
> >-8 202.112.36.242 PIM [210.25.133.0/24]
> >-9 beijing-sgw.cernet.net (202.112.1.218) PIM/MBGP [210.25.133.0/24]
> >-10 210.25.128.6 PIM/MBGP [210.25.133.0/24]
> >-11 210.25.129.33 PIM/MBGP [210.25.133.0/24]
> >-12 210.25.129.29 PIM [210.25.133.0/26]
> >-13 210.25.133.62
> >buaa-tgw-r5>
> >Lu Jian
> >National Lab of Software Development Environment
> >Beijing University of Aeronautics & Astronautics
> >P.R.C.
> >phone: 86-10-82317603
> >fax: 86-10-82317619
> >email:lujian at nlsde.buaa.edu.cn
