[AG-TECH] Anybody available to help us doing multicast test and debugging?
lujian
lujian at nlsde.buaa.edu.cn
Sun Jul 22 04:32:26 CDT 2001
AG-tech friends,
Our multicast seems to be opened, but we cannot receive any AG data. see the following result of our tests,
our beacon is at 210.25.133.24.
I will be on AG mud, called lujian_lj.
Thank you very much!
We still can't receive Access Grid multicast data.
We have done some test, the result is listed below, hope to be helpful for you to debug multicast routing.
these tests are done from Cisco 12008( 210.25.133.62)
test1
buaa-tgw-r5>mtrace
Source address or name: agaudio.osc.edu
Destination address or name: 210.25.133.62
Group address or name:
Multicast request TTL [64]:
Response address for mtrace:
Type escape sequence to abort.
Mtrace from 192.88.194.132 to 210.25.133.62 via RPF
>From source (agaudio.osc.edu) to destination (?)
Querying full reverse path...
0 210.25.133.62
-1 210.25.133.62 PIM/MBGP [192.88.194.0/24]
-2 210.25.129.30 PIM/MBGP [192.88.194.0/24]
-3 210.25.129.34 PIM/MBGP [192.88.194.0/24]
-4 210.25.128.5 PIM/MBGP [192.88.194.0/24]
-5 202.112.1.212 PIM [192.88.194.0/24]
-6 202.112.36.241 PIM [192.88.194.0/24]
-7 202.112.36.130 PIM/MBGP [192.88.194.0/24]
-8 tppr-atm1-0-0-11.jp.apan.net (203.181.248.114) [AS 7660] PIM/MBGP [192.88.194.0/24]
-9 tpr2-atm0-0-0-2.jp.apan.net (203.181.248.234) [AS 7660] PIM [192.88.194.0/24]
-10 abilene-tpr2.jp.apan.net (203.181.248.133) [AS 7660] PIM/MBGP [192.88.194.0/24]
-11 clev-ipls.abilene.ucaid.edu (198.32.8.26) [AS 11537] PIM/MBGP [192.88.194.0/24]
-12 krc4-atm1-0-0s1.ohio-gigapop.net (192.88.192.34) [AS 3112] PIM [192.88.194.0/24]
-13 krc1-atm1-0-0s4.columbus.oar.net (192.88.192.70) [AS 3112] PIM [192.88.194.128/25]
-14 osc1-atm0-0s1.columbus.oar.net (192.88.194.6) [AS 3112] PIM [192.88.194.128/25]
-15 agaudio.osc.edu (192.88.194.132)
buaa-tgw-r5>
test2
buaa-tgw-r5>mtrace
Destination address or name: 210.25.133.24
Group address or name: 233.2.171.1
Response address for mtrace: 210.25.133.62
Mtrace from 192.88.194.132 to 210.25.133.24 via group 233.2.171.1
0 210.25.133.24
-1 210.25.133.62 PIM [192.88.194.0/24]
-2 210.25.129.30 PIM [192.88.194.0/24]
-3 210.25.129.34 PIM Reached RP/Core [192.88.194.0/24]
buaa-tgw-r5>
test3
buaa-tgw-r5>mtrace
Source address or name: ws-video.mcs.anl.gov
Mtrace from 140.221.34.1 to 210.25.133.62 via RPF
>From source (ws-video.mcs.anl.gov) to destination (?)
0 210.25.133.62
-1 210.25.133.62 PIM/MBGP [140.221.0.0/16]
-2 210.25.129.30 PIM/MBGP [140.221.0.0/16]
-3 210.25.129.34 PIM/MBGP [140.221.0.0/16]
-4 210.25.128.5 PIM/MBGP [140.221.0.0/16]
-5 202.112.1.212 PIM [140.221.0.0/16]
-6 202.112.36.241 PIM [140.221.0.0/16]
buaa-tgw-r5>
test4
buaa-tgw-r5>mtrace
Mtrace from 140.221.34.1 to 210.25.133.24 via group 233.2.171.1
0 210.25.133.24
-1 210.25.133.62 PIM [140.221.0.0/16]
-2 210.25.129.30 PIM [140.221.0.0/16]
-3 210.25.129.34 PIM Reached RP/Core [140.221.0.0/16]
buaa-tgw-r5>
test5
buaa-tgw-r5>mtrace
Source address or name: 210.25.133.62
Destination address or name: 192.88.194.6
Mtrace from 210.25.133.62 to 192.88.194.6 via RPF
>From source (?) to destination (osc1-atm0-0s1.columbus.oar.net)
0 osc1-atm0-0s1.columbus.oar.net (192.88.194.6)
-1 osc1-atm0-0s1.columbus.oar.net (192.88.194.6) [AS 3112] PIM [default]
-2 krc1-atm1-0-0s1.columbus.oar.net (192.88.194.5) [AS 3112] PIM/MBGP [210.25.133.0/24]
-3 krc4-atm5-0-0s3.ohio-gigapop.net (192.88.192.69) [AS 3112] PIM/MBGP [210.25.133.0/24]
-4 abilene.ohio-gigapop.net (192.88.192.33) [AS 3112] PIM/MBGP [210.25.133.0/24]
-5 ipls-clev.abilene.ucaid.edu (198.32.8.25) [AS 11537] PIM/MBGP [210.25.133.0/24]
-6 tpr2-atm-0-0-0-13.jp.apan.net (203.181.248.134) [AS 7660] PIM [210.25.133.0/24]
-7 tppr-atm1-0-0-3.jp.apan.net (203.181.248.233) [AS 7660] PIM/MBGP [210.25.133.0/24]
-8 cernet-tppr.jp.apan.net (203.181.248.113) [AS 7660] PIM/MBGP [210.25.133.0/24]
-9 202.112.36.132 PIM [210.25.133.0/24]
-10 202.112.36.242 PIM [210.25.133.0/24]
-11 beijing-sgw.cernet.net (202.112.1.218) PIM/MBGP [210.25.133.0/24]
-12 210.25.128.6 PIM/MBGP [210.25.133.0/24]
-13 210.25.129.33 PIM/MBGP [210.25.133.0/24]
-14 210.25.129.29 PIM [210.25.133.0/26]
-15 210.25.133.62
test6
buaa-tgw-r5>mtrace
Source address or name: 192.88.194.6
Mtrace from 192.88.194.6 to 210.25.133.62 via RPF
>From source (osc1-atm0-0s1.columbus.oar.net) to destination (?)
0 210.25.133.62
-13 krc1-atm1-0-0s4.columbus.oar.net (192.88.192.70) [AS 3112] PIM [192.88.194.4/30]
-14 osc1-atm0-0s1.columbus.oar.net (192.88.194.6) [AS 3112] PIM [192.88.194.4/30]
-15 osc1-atm0-0s1.columbus.oar.net (192.88.194.6)
buaa-tgw-r5>
test7
buaa-tgw-r5>mtrace
Source address or name: 140.221.20.124
Mtrace from 140.221.20.124 to 210.25.133.62 via RPF
>From source (stardust-msfc-20.mcs.anl.gov) to destination (?)
0 210.25.133.62
test8
buaa-tgw-r5>mtrace
Destination address or name: 140.221.20.124
Mtrace from 210.25.133.62 to 140.221.20.124 via RPF
>From source (?) to destination (stardust-msfc-20.mcs.anl.gov)
0 stardust-msfc-20.mcs.anl.gov (140.221.20.124)
-1 stardust-msfc-20.mcs.anl.gov (140.221.20.124) [AS 683] PIM [default]
-2 kiwi.anchor.anl.gov (140.221.20.97) [AS 683] PIM/MBGP [210.25.133.0/24]
-3 abilene-anl.anchor.anl.gov (192.5.170.170) [AS 683] PIM/MBGP [210.25.133.0/24]
-4 tpr2-atm-0-0-0-13.jp.apan.net (203.181.248.134) [AS 7660] PIM [210.25.133.0/24]
-5 tppr-atm1-0-0-3.jp.apan.net (203.181.248.233) [AS 7660] PIM/MBGP [210.25.133.0/24]
-6 cernet-tppr.jp.apan.net (203.181.248.113) [AS 7660] PIM/MBGP [210.25.133.0/24]
-7 202.112.36.132 PIM [210.25.133.0/24]
-8 202.112.36.242 PIM [210.25.133.0/24]
-9 beijing-sgw.cernet.net (202.112.1.218) PIM/MBGP [210.25.133.0/24]
-10 210.25.128.6 PIM/MBGP [210.25.133.0/24]
-11 210.25.129.33 PIM/MBGP [210.25.133.0/24]
-12 210.25.129.29 PIM [210.25.133.0/26]
-13 210.25.133.62
buaa-tgw-r5>
Lu Jian
National Lab of Software Development Environment
Beijing University of Aeronautics & Astronautics
P.R.C.
phone: 86-10-82317603
fax: 86-10-82317619
email:lujian at nlsde.buaa.edu.cn
