[AG-TECH] problems of configurate AP800 using ATP(Audio prfect tools)
Jonas Talandis
jonast at evl.uic.edu
Tue Jul 10 10:31:39 CDT 2001
I recall there is a baud rate setting in the APTools config that has to
match the hardware setting.....
At 03:05 AM 7/10/01 , Robert Olson wrote:
>Any changes you make in the APTools application should take effect
>immediately -- you don't need to take any explicit action to program it.
>Does it appear to not be working that way?
>--bob
>At 01:00 PM 7/10/2001 +0800, lujian wrote:
>>We are trying to employ an AP800 in our AccessGrid meeting room. It works
>>well. We can also configurate it by the front panel. But we can't using
>>ATP to change the settings. Whatever changes we did in ATP, it can not be
>>written back to AP800. We pressed the "program unit" button in toolbar
>>several times, but it seems that nothing happened. We are sure the cable
>>we used to connect the AP800 to PC is right, because we can communicate
>>to AP800 by HYPERTRM.EXE(HyperTerminal). And we are sure the ATP is the
>>lastest version(it was download from Gentener yesterday). Could anyone
>>tell us what is wrong? Is there some settings on AP800 should be changed
>>before we use ATP?
Jonas Talandis
Electronic Visualization Laboratory
University of Illinois at Chicago
voice: +1-312-996-3002
fax: +1-312-413-7585
www.evl.uic.edu
