[AG-TECH] Re:
Satish K. Vanimisetti
satish at mailhost.ccs.uky.edu
Wed Feb 28 12:22:45 CST 2001
just had tried that..
worked
Thanks
On Wed, 28 Feb 2001, Robert Olson wrote:
That might be from having run vrm as root at some point, then running as a
normal user. Try, as root, removing /tmp/vic-startup* and retrying
vrm-eventlistener as a normal user.
--bob
At 01:14 PM 2/28/2001 -0500, Satish K. Vanimisetti wrote:
>Hi Bob,
>I have this error on my video machine, when using VV.
>setting address to 224.2.177.155
>Start capture
>runtime is /tmp/vic-startup.0
>Forcing to device /dev/video0
>Monitor thread starting!
>Start capture
>runtime is /tmp/vic-startup.1
>Can't open stream on /tmp/vic-startup.1: java.io.FileNotFoundException:
>/tmp/vic-startup.1
>here is the output for 'ls' on /tmp:
>-rw-rw-r-- 1 gazula gazula 608 Feb 28 09:05 vic-startup.0
>-rw-r--r-- 1 root root 596 Dec 28 19:13 vic-startup.1
>-rw-r--r-- 1 root root 596 Dec 28 19:13 vic-startup.2
>Thanks
>-Satish
