[AG-TECH] RAT not finding audio card
Mark D. Johnson
mjohnson at sc.rr.com
Wed Feb 28 10:12:07 CST 2001
Don,
There may be an issue with the OSS for that card. If it's the SB live, like I
have, I don't think the OSS will work. BTW are you using more than one card? I think
one is all you need. What does the system say at boot time, does it say that it's
loading the sound system?
When I decided to try Linux RH 7.0, that seemed to fix my driver problem; just had to
install a new Java runtime.
-mark
Don Morton wrote:
> All, to add more info to the equation (please just ignore this all
> if it ain't your cup of tea :):
> - I am using the Creative SB 128 audio cards (I think, just
> for the halibut, I'll pull two of them just to remove them
> from the equation.)
> - I am using the OSS drivers obtained from 4front
> - I am appending the output of "cat /dev/sndstat" to this message.
> I don't know what "all" of it means (yet), but it appears that things
> are being found, anyway....
> Thanks again, Don
> Don Morton wrote:
> > Hi all, I've found the likely reason that I can't receive anybody's
> > audio is that rat isn't finding my audio card. Apparently, being
> > able to hear a Neil Young cd or a RealAudio stream (which I guess
> > operates in half-duplex) is no guarantee that rat will work (which
> > I guess operates in duplex. Essentially, when I go through the audio
> > menu of rat, under the "select alternate devices" (or something like
> > that section, the only option is something like "No Audio Device"
> > I "guess" that maybe there's an IRQ assignment problem that "maybe"
> > I need to look into but, in /var/log/messages, at boot, I get
> > a message saying:
> > Feb 27 15:34:57 AGNAudioCapture modprobe: modprobe: Can't locate module sound-sl
> > ot-0
> > Feb 27 15:34:57 AGNAudioCapture modprobe: modprobe: Can't locate module sound-se
> > rvice-0-6
> > Does anybody know if these are actually needed by rat, or am I probably safe
> > ignoring
> > this?
> [root at AGNAudioCapture log]# cat /dev/sndstat
> OSS/Linux 3.9.4c (C) 4Front Technologies 1996-2000
> License serial number: N02680983
> Options: APCI
> This copy of OSS is licensed to Don Morton
> Build: 2.2.18-SMP
> Card config:
> Ensoniq AudioPCI 97 at 0xdf00 irq 20
> Ensoniq AudioPCI 97 at 0xde80 irq 18
> Ensoniq AudioPCI 97 at 0xdd80 irq 16
> Audio devices:
> 0: Ensoniq AudioPCI97 (DUPLEX)
> 1: Ensoniq AudioPCI97 (playback only)
> 2: Ensoniq AudioPCI97 (DUPLEX)
> 3: Ensoniq AudioPCI97 (playback only)
> 4: Ensoniq AudioPCI97 (DUPLEX)
> 5: Ensoniq AudioPCI97 (playback only)
> Synth devices:
> Midi devices:
> 0: AudioPCI97
> 1: AudioPCI97
> 2: AudioPCI97
> Timers:
> 0: System clock
> Mixers:
> 0: AudioPCI 97 (STAC9708)
> 1: AudioPCI 97 (STAC9708)
> 2: AudioPCI 97 (STAC9708)
Mark D. Johnson
Information Technology Manager
University of South Carolina
300 Main Street Rm. A-139A IMS
Columbia, SC 29208
(803) 777-9520/0762 Fax (803) 777-9557
Mobile (803) 319-0081
mjohnson at sc.edu
H.323 129.252.29.101/109
http://iris.sc.edu/ecard.asp?ID=1242
Type: text/x-vcard
Desc: Card for Mark D. Johnson
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20010228/656bdbde/attachment.vcf>
