[AG-TECH] Multicast workaround?
Jennifer Teig von Hoffman
jtvh at bu.edu
Fri Feb 23 14:41:14 CST 2001
Hi Don,
Here's some info on the multicast/unicast bridge. Others are more
qualified than I to talk about tunnelling (heck, others are more qualified
than I to talk about bridging too, so somebody jump in here if I'm
forgetting something).
If you log into Virtual Venues and follow the links to a given room, you
will see on the web page associated with that room a list of commands. For
example, in the lobby you'd see (among other things)
Bridge: vtc AccessGridLobbyvideo bridge-1.accessgrid.org ag
Bridge: vtc AccessGridLobbyaudio bridge-1.accessgrid.org ag
You'll need to install vtc on your display, audio, and video machines (if
you haven't already). See the software download page for where to get it.
Once that's properly installed, you run those commands on the various
machines (ie, video command once on display machine, audio command once on
audio machine, video command as many times on video machine as you have
cameras). You'll probably need to make some manual adjustments in vic on
the video machine to get it to find the right camera(s) (ie, each vic
instance needs to pick up one of your cameras).
(I've gotten stuck and confused more than once by vtc not being able to
find vic, which apparently was not in my path at the time, so that's
something to watch for. Also, you'll need to either put vtc in your path
or run it from the directory it's in.)
And if you get started on all this and get stuck, jump on the Waterfall
Glen MUD -- most if not all of us have used the bridge at one time or
another. Also come hang out there if you're looking for people to do
testing with.
- Jennifer
On Fri, 23 Feb 2001, Don Morton wrote:
> Howdy, our machines are set up and ready to go (at least on a test
> basis), and we have our beacons out, but no multicast past our local
> router. Bill Nickless is in contact with our network person on this.
> In the meantime, is there a means to start trying to bring the AGN
> "live"
> without multicast? I hear terms such as "bridging" and "tunnelling" -
> are
> these approaches I might want to consider just to get us interacting
> with the outside world until our multicast is working? I'm quite
> un-knowledgeable in this area - if this is something I might want
> to consider for the short-term, would somebody be able to point
> me to some info on how I would proceed?
> No rush on an answer - I'm now heading out X-C skiing on the Idaho
> border - no computers out that way! :)
> Thanks for any help/advice,
> Don
> Don Morton http://www.cs.umt.edu/u/morton/
> Department of Computer Science The University of Montana
> Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
