[AG-TECH] XAP 800
Robert Olson
olson at mcs.anl.gov
Tue Dec 18 12:32:13 CST 2001
This is the plan for audio concepts document that I'm planning on putting
together for agdp .. roughly derived from the tutorial slides at
http://www-unix.mcs.anl.gov/~olson/AG/AudioTutorial/AudioTutorial.htm
--bob
At 08:52 AM 12/17/2001 -0600, Rick Stevens wrote:
>I think this is the right idea..
>On Mon, 17 Dec 2001, Ivan R. Judson wrote:
> > I think the goal of an audio configuration document needs to be high-enough
> > level to capture the "intent" but not the "implementation".
> > This would make the document clear enough to be a recipe for configuring
> > audio with different equipment.
> > Thoughts?
> > --Ivan
> > > -----Original Message-----
> > > From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> > > Behalf Of Mustafa Varank
> > > Sent: Monday, December 17, 2001 7:11 AM
> > > To: Allan Spale
> > > Cc: ag-tech at mcs.anl.gov
> > > Subject: Re: [AG-TECH] XAP 800
> > > Allan,
> > > Thank you for the advices but XAP 800 does look different. There are
> > > processors ( no sub?) on XAP800 and you should set "EC Reference and PA"
> > > differently. Even i tried to set it, it did not work...I am doing
> > > something
> > > wrong but i could not find...
> > > Could you please tell me also where did you put speakers on your sample
> > > matrix picture?
> > > I will be waiting to see the updated web site...
> > > Thanks,
> > > Mustafa
> > > At 03:26 PM 12/16/2001 -0600, you wrote:
> > > >Mustafa,
> > > >I have been working on creating a more up-to-date Gentner configuration
> > > >document, so I will attach an image from the document that will
> > > eventually
> > > >appear in the AGDP.
> > > >I am not sure how ifferent the XAP 800 is from an AP 400, but I would
> > > >imagine that the echo cancellation should be similar.
> > > >In the matrix, notice that Output D is labeled "Ghost Output". This
> > > >output, which should have nothing connected to it physically,
> > > will be used
> > > >in echo cancellation. This is demonstrated by looking at the bottom of
> > > >the image where you will select which output to serve as echo
> > > >cancellation.
> > > >You want to echo cancel anything that would come out of your speakers so
> > > >that the Gentner does not think that this is regular audio going
> into the
> > > >mics (or something like that...I am not a complete expert on this audio
> > > >stuff). Specifically, this would be sound from your telco and audio
> from
> > > >the AG. The AG sound should be entering an input, and the sound
> from the
> > > >telco should be "Telco in".
> > > >Create a crosspoint on the "Ghost Output" and the AG audio in
> > > row (RX from
> > > >AG) and the "Telco In" row.
> > > >In the "Echo Cancellation Setup", select the output channel that
> > > >corresponds to the output designated as the "Ghost Output". Please note
> > > >that the scenario described above is for the net-telco preset
> (preset 1).
> > > >For preset 2 (concerning the "Ghost Output" only and not the other mics,
> > > >inputs, outputs, an stuff), only have the telco crosspoint set in the
> > > >"Ghost Ouput" column. For preset 3, only have the RX from AG
> > > (or whatever
> > > >you named that input that receives audio from the AG) crosspoint set in
> > > >the "Ghost Output" column.
> > > >Also as far as general guidelines, make sure that your gain is
> > > not set too
> > > >high on the mics or this will cause echo. Aditionally, make sure that
> > > >your mics are not too close to the speakers or else you may have echo
> > > >problems.
> > > >Best of luck in figuring this problem out.
> > > >Allan
> > > >EVL at UIC
> > > >node-op
> > > >On Sun, 16 Dec 2001, Mustafa Varank wrote:
> > > > > Hello,
> > > > > Can anybody send me some suggestions about how to set echo
> > > cancellation on
> > > > > XAP 800? I am having hard time to figure it out. And if you
> > > can send it
> > > > > today or early monday morning that would be great...
> > > > > Thanks
