[AG-TECH] Re: mjpeg test
Bob Riddle
bdr at internet2.edu
Tue Dec 11 09:32:04 CST 2001
hmmm ... I see it on my latop & AG display node - though I'm on the same
network segment. The tests I've down with Surfnet using this mjpeg video
capture machine have worked well - though we've used the mjpeg capture client
at each end. But still, it means the mcast traffic has traversed the network.
Are you sure its the openmash 5.1.6 vic you're running? Whe i start it (.\vic
233.2.171.38/42002) I see a thumbnail with "delco1.internet2.edu" immediately.
Quoting Bob Olson <olson at mcs.anl.gov>:
> Hm, I'm not seeing anythin there; I'll keep the mashvic up to see what
> shows up.
> --bob
> On Tue, 11 Dec 2001, Bob Riddle wrote:
> > I've set up a mjpeg test in the AG Test Room. Its a pretty ratty
> stream, only
> > 5 mbps using CIF format but it's a test of the stuff I've gloomed
> together. In
> > order to run a hogher rate in NTSC format I need to build the openmash
> vic from
> > CVS - something I haven;t had a chance to do as yet.
> > Anyway, to see if you can see anything:
> > Download the openmash vic for windows on your display machine
> (www.openmash.org)
> > get your AG display node into the AG test room.
> > Kill the AG vic window.
> > open a cmd (DOS-like) window and star the openmash vic ".\vic
> > 233.2.171.38/42002"
> > Let me know what you see, think, etc.
> > I hope to have the necessary vic ready for a 10mbps test next Tuesday
> morning.
