[AG-TECH] Newbie-- no heartbeat
Mike Daw
mike.daw at man.ac.uk
Thu Aug 2 04:30:19 CDT 2001
2 things to check:
1. Have you run set-display-machine? Does the file this writes to have
sufficient information about the display machine (i.e. the name of the
display machine is in /etc/hosts)?
2. Event Server AND Display Manager need to be running on the Display
machine for the video machine to have a heartbeat (though the converse is
not true).
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Ruth Lang
> Sent: 02 August 2001 09:21
> To: ag-tech at mcs.anl.gov
> Cc: ruth.lang at hlrs.de
> Subject: [AG-TECH] Newbie-- no heartbeat
> Since a few days I've been working on setting up our AG node.
> On the display machine all things run well.
> On the video machine I don't get a heartbeat, but a solid dot next to
> "Connected". Instead the following messages appear in the
> terminal window.
> Card info for visagvideo.hlrs.de: device=v4l- BT878(Hauppauge
> new) /dev/video0
> input=S-Video
> purpose=MAIN
> cardNumber=2
> enabled=true
> create listener
> Got event channel
> org.omg.CosEventChannelAdmin.StubForEventChannel:com.ooc.CORBA
> .Delegate at 5929f6d2
> Got newstate true
> Look for cache
> Create watchdog app=ag.VideoResourceManager at 2fdf6d2
> Watchdog thread starts
> Missed heartbeat!
> Mssed a second heartbeat, trying reconnect
> disconnect sdp channel listener
> Got newstate false
> create listener
> Got event channel
> .Delegate at 5af5f6d2
> Got newstate true
> reconnect succeeded!
> Missed heartbeat!
> Got newstate false
> create listener
> Got event channel
> .Delegate at c19df6d2
> Got newstate true
> Missed heartbeat!
> Window closing
> The TCP connection between the video and the display machine
> exists and all
> machines know each other.
> Can somebody tell me what is wrong in my configuration.
> Thanks in advance
> Ruth Lang
> High Performance Computing Center Stuttgart
> email: ruthlang at hlrs.de
