[AG-TECH] Announcing a secure network test framework . . . .
    Deb Agarwal
    DAAgarwal at lbl.gov
    Wed Apr 25 18:51:44 CDT 2001
Thought you might be interested in the tool we just released.
This message is to announce the alpha release of Nettest, a secure,
real-time network monitoring framework developed in the Distributed
Systems Department at Lawrence Berkeley National Lab.
The Nettest framework is designed to incorporate existing and new
network tests, and be run as a daemon or an interactive process.
Requests for network tests are received via a SSL connection or
the user interface and are authorized using an ACL list (in the
future authorization using Akenti will also be supported).
For tests that require coordination between the two ends of the test,
Nettest establishes a SSL connection to accomplish this coordination.
A test between two remote computers can be requested via the user
interface if the Nettest daemon is running on both remote machines
and the user is authorized.  Authorization for the test is through a
chain of trust established by the Nettest daemons.  Nettest is
responsible for determining if the test request is authorized, but it
does nothing further to secure the test once the test is running.
Currently the Nettest framework incorporates Iperf-v1.2, a simple
ping type test, and a tuned TCP test that uses a given required
throughput and ping results to determine the round trip time to set
a buffer size (based on the delay bandwidth product) and then performs
an Iperf  TCP throughput test. Additional network test tools can be
integrated into the Nettest framework in the future.
Nettest was tested and developed on Linux and Solaris.  Nettest is
written in C++, primarily using gcc but also tested on SparcWorks C++.
Secure communication is implemented using SSL-v0.9.6.
To run Nettest you will need the latest version of Openssl.
    http://www.openssl.org/source/
NetLogger can be used for result reporting purposes, it will allow you
to send all test results to one location.
    http://www-didc.lbl.gov/NetLogger/
More information on Nettest and downloadable source code can be found
at:
    http://www-itg.lbl.gov/nettest
The Iperf network testing tool can be found at:
  http://dast.nlanr.net/Projects/Iperf/
  The Iperf tool was developed by the distributed applications support
  team of the National Laboratory for Applied Network Research (NLANR).
  comments specific to Iperf, mail to dast at nlanr.net
Please email Nettest questions or comments to:
Deborah A. Agarwal      DAAgarwal at lbl.gov and
Joshua R. Boverhof      JRBoverhof at lbl.gov
CREDITS: Our core program is supported by the Office of Energy Research, Office
of Computation and Technology Research , Mathematical, Information, and
Computational Sciences Division, of the U. S. Department of Energy under
contract No. DE-AC03-76SF00098 with the University of California.
ippm mailing list
ippm at advanced.org
http://mailhost.advanced.org/mailman/listinfo/ippm
