Fwd: Re: [AG-TECH] RE: AG Packaging Effort
Steven I. Gordon
sgordon at osc.edu
Tue Apr 24 10:23:30 CDT 2001
There is a set of draft documentation that might answer your initial
questions. You can see that at http://www.osc.edu/accessgriddoc/
>X-Sender: randy at redwood.rt.cs.boeing.com
>X-Mailer: QUALCOMM Windows Eudora Version 5.0.2
>Date: Tue, 24 Apr 2001 08:13:18 -0700
>To: "Ag-Tech at Mcs. Anl. Gov" <ag-tech at mcs.anl.gov>
>From: Randy Groves <randy.groves at boeing.com>
>Subject: Re: [AG-TECH] RE: AG Packaging Effort
>Sender: owner-ag-tech at mcs.anl.gov
>I would like to extend Gregor's request. I've looked through the web site
>extensively (but maybe not exhaustively), and do not see a list of 'specs'
>for a lot of the support equipment such as video capture cards,
>projectors, and sound cards. There are suggestions of models that have
>worked, but I do not see - at least collected in one place - a discussion
>of what it was about the suggested model that made it a fit. What specs
>were essential on the suggested models? Were they picked because drivers
>existed for Linux? What physical I/O connections are essential? I find
>that several of the suggestions are hard to get, and/or have been replaced
>by newer models, and lacking the required specs, it makes it difficult to
>determine if an available model will suffice. I have read the Hardware
>Spec document, and does contain good specs for the computing requirements,
>but it is lacking on the other specs.
>I realize that there may be a bit of experimentation required in all this,
>and I also realized that I may have missed the information somewhere on
>the site. So if someone can point out my ignorance that's fine by me.
>-randy
>At 09:14 AM 4/24/2001 -0500, Gregor von Laszewski wrote:
>>Dear All:
>> would it be possible to get a precise "small" list of features of a
>>mandatory Linux machine that is part of an access grid node. E.g. which os
>>version, ....,
>> Or is there a great deal of flexibility on these machines?
>>Thanks
>>Gregor
>>-----Original Message-----
>>From: owner-accessgrid at mcs.anl.gov
>>[mailto:owner-accessgrid at mcs.anl.gov]On Behalf Of Lisa Childers
>>Sent: Monday, April 23, 2001 7:35 PM
>>To: Ag-Tech at Mcs. Anl. Gov; Accessgrid at Mcs. Anl. Gov
