Projection Surfaces
    John A. Greenfield
    green at ahpcc.unm.edu
    Fri Oct 27 15:03:24 CDT 2000
One other thing about the wall-talker. Make sure the walls are smooth
before you put it up -- bumps are bad. One solution if the walls are
textured or otherwise rough is to put up new sheetrock and apply the
walltalker to that (we wound up doing that at UNM as new sheetrock
installation was significantly cheaper than having the texture sanded off
the wall).
John Greenfield
University of New Mexico
THE ALBUQUERQUE HIGH PERFORMANCE COMPUTING CENTER
Office # 505-277-8249
Direct # 505-277-9545
Fax #    505-277-8235
