Projection Surfaces
    Jonas Talandis
    jonast at evl.uic.edu
    Thu Oct 26 10:40:41 CDT 2000
My experience is that it's a good idea to sketch out your projector
placement first. The image aspect is 4:3 so for a 3x1 image, that's 12:3.
If your wall is 10' wide that allows for a display height of about 2.5'.
Check your projector specs for the corresponding distance from the screen
for the desired image size. The zoom capability of the lens gives you a
range within you can place your projectors. I recommend ceiling mounts for
a permanent installation but in any case you need to work around any
mounting interference from lights, pipes, beams etc.
JT
At 06:33 PM 10/25/00 , Don Morton wrote:
>You all bring up good points, so I'll abandon the thought of 3 small
>bargain-basement screens.  I've considered the wallpaper route myself.
>Does anybody know just how wide this wallpaper is?  Has anybody had
>any problems with it not erasing completely after being used as
>a whiteboard?
>With our small room, our projection surface will be roughly 10',
>and I anticipate projector images of roughly 3.3' x 3.3'.  So,
>hopefully two strips of the wallpaper would do the job.  Still
>haven't made a firm decision on wallpaper though.  Other possibility
>is to just buy a 10' wide screen that pulls down over an existing
>whiteboard.
>    Don Morton                     http://www.cs.umt.edu/u/morton/
>    Department of Computer Science       The University of Montana
>    Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
