Projection Surfaces
    Jason Leigh
    spiff at evl.uic.edu
    Wed Oct 25 17:20:58 CDT 2000
We, at EVL have been driving our AG node with 3, 52" Plasma screen and 1
silver screen on the side for future passive stereoscopic projection. The
plasma screens are very bright and so you can have full florescants on and
still see the screen clearly.
We are also testing in a separate room a touch screen mounted over a plasma
screen to provide you with the ability interact with the screen directly so
for example you'll be able to walk up to an annotation screen and write on
it and have it shared with other AGers.
Jason
Jason Leigh, PhD
spiff at evl.uic.edu              Electronic Visualization Lab (M/C 154)
EVL Phone (312) 996-3002         University of Illinois at Chicago
EVL FAX   (312) 413-7585         851 S. Morgan St. Room 1120 SEO
http://www.evl.uic.edu/spiff     Chicago, IL 60607-7053
> -----Original Message-----
> From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov]On
> Behalf Of Mark D. Johnson
> Sent: Wednesday, October 25, 2000 5:11 PM
> To: Jennifer Teig von Hoffman
> Cc: Don Morton; ag-tech at mcs.anl.gov
> Subject: Re: Projection Surfaces
> Don,
>     We at USC are going the wallpaper route (WallTalker) to save space as
> well as money.  The three projectors that we are going to use
> have 2k lumens
> each and should give a very sharp picture.   This will be similar to ANL's
> setup we saw in September.  I feel that having one screen with the 2 or 3
> projectors merged together will give a cleaner appearance and keep the eye
> from focusing on one particular screen.
> -mark
> Jennifer Teig von Hoffman wrote:
> > FWIW, BU uses a rear-projection screen, and it makes a real
> difference in
> > the quality of the image (and of the user-experience, since people can
> > walk across the screen and stuff without disrupting images).
> When we were
> > projecting against the wall (perhaps the cheapest imaginable projection
> > surface?) we could function okay, but some image detail seemed to get
> > lost.
> > So. . . issues regarding screen selection are probably broader than just
> > output merging (which we don't do here, though we do have our projectors
> > lined up reasonably well).
> > - Jennifer
> > On Wed, 25 Oct 2000, Don Morton wrote:
> > > Howdy, as we get in the process of ordering equipment, etc., I'm still
> > > considering what to use for a projection surface.  I'm not clear
> > > on whether it's important to be able to "merge" the output
> > > from 2 or 3 projectors into a single image.  If that's not an
> > > important issue, couldn't we just get away with 3 small,
> CHEAP screens,
> > > one for each projector?
> > > I don't think I've seen an example of "merged" projections, though I
> > > recall at ANL, there might have been an attempt at that.
> > > Thanks, Don
> > >    Don Morton                     http://www.cs.umt.edu/u/morton/
> > >    Department of Computer Science       The University of Montana
> > >    Missoula, MT 59812 | Voice (406) 243-4975 | Fax (406) 243-5139
