problems with latest VV
Robert Olson
olson at mcs.anl.gov
Wed Nov 22 11:36:08 CST 2000
Yes, not having DNS is currently a problem. In the next release of VV code
I'll make it easier to turn on the use-IP-addresses-instead-of-hostnames
option in the Corba runtime.
--bob
At 11:30 AM 11/22/2000 -0600, you wrote:
>That was the last thing I was going to try. Currently the 2 machines
>involved are not in DNS and I just used the IP address there. Is it a
>known issue to not have the machines entered in DNS?
>Jeff Long
>Robert Olson wrote:
> > That sounds like the display machine isn't set right on that machine - can
> > you doublecheck /usr/local/ag/lib/node-config and verify that DISPLAY_HOST
> > is set to the right machine?
> > At 10:45 AM 11/22/2000 -0600, Jeff Long wrote:
> > >I've installed the latest release of the VV software from Bob's
> > >redhat-2000-1103-1529.iso on both my Linux box and my Win2K machine. I'm
> > >having problems using the arm-eventlistener. It sort of works but I can't
> > >have it automatically follow the DRM into a new room for example. I'm
> > >also getting these messages *continuously*:
> > >Got event channel org.omg.CosEventChannelAdmin.StubForEventChannel at 80dc1e9
> > >Listener create failed
> > >create listener
> > >Got event channel org.omg.CosEventChannelAdmin.StubForEventChannel at 80dc1d5
> > >create listener
> > >Got event channel org.omg.CosEventChannelAdmin.StubForEventChannel at 80dc1c1
> > >Any suggestions on what is wrong?
> > >Jeff Long
