Addition to spec
Robert Olson
olson at mcs.anl.gov
Fri May 26 11:09:59 CDT 2000
Do you have any suggestions for rack-mounting them? I've not figured out a
good way to do that yet ..
thanks,
--bob
At 10:03 AM 5/26/2000 -0600, Don Middleton wrote:
>Robert Olson writes:
> > Just wanted to send a note about a very useful device that helps in level
> > matching quite a bit. Consider it an official addition to the AG node
> spec :-).
> > It's an ATI MatchMaker MM100. It converts between pro-audio and
> > consumer-audio levels, which goes between the Gentner and the PC. It has
> > XLRs for going to the gentner, and RCAs for going to the PC. This lets you
> > use a standard 1/8" to RCA cable for the PC side, and the genetner/XLR
> > cables you all love for the gentner side.
> > http://www.markertek.com/MTStore/product.CFM?BaseItem=MM100
>And a fine addition it is. I've been using these boxes for many years now
>and can vouch for their usefulness. Anyone who's mixing consumer
>line-level and pro balanced audio should have several of these;
>they're indispensable, imo.
>don
